binding the 3 port in single segment
sdmcet
hi,i want to bind the following code in single segments.the following code consist of 3 libraries and 3 ports,so my problem is make it as single port,so that it's very easy for me to create test bench.please help me.
thank u
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
library ieee; --LIBRARY DECLARATION
use ieee.std_logic_1164.all;
entity gencoder24 is  --ENTITY DECLARATION
 port(  start:in std_logic;
    insym:std_logic_vector(1 to 12);
    codeword: out std_logic_vector(1 to 24)
end gencoder24;
architecture behave of gencoder24 is
type matrix is array(1 to 144) of std_logic;
signal generato: matrix;
begin
 process(start,generato)
   variable ctr: integer;
   variable setbit,p:std_logic;
   begin
     if (start='1') then
     generato<=("011111111111111011100010110111000101101110001011111100010110111000101101110001011011100010110111100101101110101011011100110110111000101101110001"); --NON IDENTITY PART OF GENERATOR
     ctr:=1;
     for j in 1 to 12 loop
       p:='0';
       for i in 1 to 12 loop
         setbit:=(insym(i) and generato(ctr));
         if (setbit='1') then
           p := not p;
         end if;
         ctr := ctr+1;
       end loop;
       codeword(j+12)<=p ;
     end loop;
       codeword(i)<=insym(i);
     end loop;
end if;
end process;
end behave;
library ieee;
entity inpbus24 is
 port(i1,i2,i3,i4,i5,i6,i7,i8,i9,i10,i11,i12,i13,i14,
    i15,i16,i17,i18,i19,i20,i21,i22,i23,i24:in std_logic;
    mx:out std_logic_vector(1 to 24)
end inpbus24;
architecture behave of inpbus24 is
begin
 mx(1)<=i1;
 mx(2)<=i2;
 mx(3)<=i3;
 mx(4)<=i4;
 mx(5)<=i5;
 mx(6)<=i6;
 mx(7)<=i7;
 mx(8)<=i8;
 mx(9)<=i9;
 mx(10)<=i10;
 mx(11)<=i11;
 mx(12)<=i12;
 mx(13)<=i13;
 mx(14)<=i14;
 mx(15)<=i15;
 mx(16)<=i16;
 mx(17)<=i17;
 mx(18)<=i18;
 mx(19)<=i19;
 mx(20)<=i20;
 mx(21)<=i21;
 mx(22)<=i22;
 mx(23)<=i23;
 mx(24)<=i24;
end behave;
library ieee;
entity gdtotal2 is
port(rxsym: in std_logic_vector(1 to 24);
  s : out std_logic_vector(1 to 12);
  tns: out std_logic_vector(1 to 24);
  nsa:out std_logic
end gdtotal2;
architecture behave of gdtotal2 is
signal generato : std_logic_vector(1 to 144);
signal e : std_logic_vector(1 to 24);
type bit12 is array(1 to 12) of std_logic;
begin
process(rxsym)
variable ctr,wtctr:integer; --ctr TRACK OF GENERATOR MATRIX
 variable setbit,p,ns:std_logic; -- TEMPORARY VARIABLES
variable syntemp:bit12; -- TEMPORARY 12-BIT VECTOR FOR SYNDROME
begin -- OF PROCESS ...
 --STEP 2 STARTS...
 ctr:=1;
   p:='0';
   for i in 13 to 24 loop
     setbit:=rxsym(i) and generato(ctr);
p := not p;
     end if;
     ctr :=ctr+1;
   end loop;
   syntemp(j):=p;
 end loop;
   syntemp(i):=syntemp(i) xor rxsym(i);
   s(i)<=syntemp(i);
 end loop;-- END OF SYNDROME CALCULATION.
 --STEP 2 ENDS.
 --STEP 3 STARTS...
 wtctr:=0;--CALCULATING WEIGHT OF SYNDROME...
   if(syntemp(i)='1') then
     wtctr:=wtctr+1;
   end if;
 end loop;
 if (wtctr<=3) then-- CHECKING CONDITION...
   ns:='0';
   for i in 1 to 12 loop --FIRST 12 BITS OF ERROR VECTOR
   -- ASSIGNED THE SYNDROME.
     e(i)<=syntemp(i);
   end loop;
   for i in 13 to 24 loop--THE NEXT 12 ARE MADE 0.
     e(i)<='0';
   end loop;
 else--IF CHECK FAILS, ERROR VECTOR SET TO ZERO...
   for i in 1 to 24 loop
     e(i)<='0';
   end loop;
   ns:='1';
 end if;
 for i in 1 to 24 loop--XORING THE RECEIVED VECTOR WITH ERROR VECTOR
     tns(i)<= e(i) xor rxsym(i);
 end loop;
 nsa<=ns; --FLAG FOR ACTIVATING THE NEXT STEPS IN THE ALGORITHM.
end process;
end behave;-- END OF ARCHITECTURE BEHAVE
