Terminator3
Advanced Member level 3
I have doubts about biasing of balanced FET amplifier. Assume single FET amplifier works perfectly biasing is tuned to some VGs and VDs values. VDs is set by Rdrain resistor. Now we put the same layout and connect it with existing one with high impedance lines (drain1 to drain2, gate1 to gate2), and use halved value for Rdrain. What problems should i expect?
I want to use non-symmetrical arrangement of power lines. Maybe more current will flow through one FET than another (placed farther away). Usually thin supply lines placed symmetrically, for example at power divider/combiner microstrip.
Here is an illustration to make my question more clear:
Is there any possible problems when moving power lines to this new non-symmetrical position?
source of image: **broken link removed**
