Biasing CMOS analog design
chiragjain146
Newbie level 3
Newbie level 3
Need help in generating Bias Voltage Vb( i.e. of 2nd pmos of cascode from top)
May i know the supply voltage ... and whats your output voltage?
And use the upper Pmos current source bias or use seperate leg if you want precise bias voltage.. It depends on you...
Thanks
Thanks
actually my qsn states that i need a high CMRR and high swing(2.2v)
supply is 3.3v... so a diode connected bias wont work
sry forgot to mention cant use resistors...
as of now i have done using a diode connected pmos(with a different W/L) and gave its gate volatge...
but the matching isnt perfect
Instead, try and use a (small) pmos with its gate connected to GND or to one of the n-bias voltages. Or an nmos with its gate connected to the upper p-bias voltage, or to VDD.
Hi Chirag,
As u need good output swing, you can go with Low voltage Cascode Current Mirror circuit mention in Razavi.
One more point : In your circuit How You are generating gate bias for your PMOS tail current mirrors. It looks like your PMOS (diode connected 3rd branch) is off.
