Best way to program a atmega
this is a usb asp programmer that means you have to construct the pcb & place the usb conector to it & burn the hexcode which you wanted thats all
So, i start developing a atmega64 board, and i want to know the best way to program it?
I was think to use one of those: https://www.hobbyking.com/hobbyking/store/__21321__usbasp_avr_programming_device_for_atmel_proccessors.html
Will it work? Does that kind of programmer works with Ponyprog?
Is USB-TTL cable better for this aplication?
Can you define "best way" ?
You can use USBasp or any other programmer suitable for this uC, or as additional solution you can use bootloader.
With USBasp you can use :
AVRDUDE supports USBasp since version 5.2.
BASCOM-AVR supports USBasp since version 1.11.9.6.
Khazama AVR Programmer is a Windows XP/Vista GUI application for USBasp and avrdude.
eXtreme Burner - AVR is a Windows GUI Software for USBasp based USB AVR programmers.
USBasp project page
https://www.fischl.de/usbasp/
Best regards,
Peter
USBasp project page
Best regards,
Peter
Thanks Peter, i downloaded the extreme burner and it look like a good software. When i said "best way" i was meaning "easy way".
Now i only have to finish the layout for my board, and play with it.
Easy way give new light on this, you can see this programmer AVR ISP programmer you need only few parts, serial port and PonyProg software:
AVR Serial Port Programmer
https://www.circuitvalley.com/2011/04/avr-serial-port-programmer.html
There is one additional also simplified version of AVR programmer which use one IC (74HC244) and LPT port. If you need that say, but first simple version will do the job.
Best regards,
Peter
Hi
My 2 cents. It is good to start with self made programmer, but if you going to use Atmel AVR for long (as most get addicted to it), please invest in a good programmer. There is a good reason to it. When programming devices a lot of data is transfered and the data lines switch rapidly generating spikes. The Atmel programmers have schottky protection diodes on all lines minimising these spikes.
This is what I copied from the specs of AVRISP mkII
•Target interface protection
•Short-circuit protection
I am having a functional home made programmer for many years (I do use it sometimes). It has all protection using normal diodes but still I have purchased AVRISP mkII just to be sure.
