vasudevan.palani
Newbie level 3
- Joined
- Aug 12, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 23
I am planning to do home automation using microcontrollers.
The application has to be power efficient, Normally a +5 is required all times to make the relay close the circuit.
Latching relay seems to be a good option, however, have couple of concerns though
1. I think, it can be only switched on ( just like traic ), cannot be switched off ( isnt that so ?)
2. I dont get latching relays in my place.
Requirement, i should be able close a AC circuit ( 230V, 4A, 50Hz ) from a Microcontroller I/O pin. I should also be able to open the AC circuit as well.
IGBT seems to be a good, however, its very costly.
Is there any other cheap and energy efficient solution?
Thanks
-Vasu
Thanks
-Vasu
