abdoalghareeb
Member level 5
- Joined
- Feb 5, 2010
- Messages
- 84
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,981
In my design of 12VDC to 220VAC inverter, This is the schematic part for charging (12v/100Ah) battery.
I use AVR ATmega 8 micro controller
There are three steps for charging (three primary coils) controlled by three relays (R1,R2,R3)
And I have two feed back signals , battery voltage and secondary coil (13VAC) which read the input voltage on primary (220VAC) .
I need the charging flowchart or program code or the steps for standard charging, depending on the analog input signal, because the AC on primary can vary (180 - 220) and the full charge voltage (15 VDC).
