Piezoelectric Battery Charger
shreyrohilla
Newbie
Newbie level 1
For a project that I am conducting, I am trying to create a device that can successfully charge a 1.2v NiMH battery using 6 piezoelectric transducers. Per step of the device, the transducers produce around 50V and 40mA. I came up with this circuit,
main-qimg-020a42f0bfc652a3823490ad6a9cd318-pjlq
but for some reason, the capacitor only charges up to 1.3–1.5v and is only able to charge the battery up from 0.8v to 1.07–1.10v no matter what. I am a little confused as to why it is not able to fully charge the battery, and if this is even the best way to efficiently charge this battery.
I am using 1n4007 diodes for the full bridge rectifiers and a 47uF 50v capacitor.
FvM
Super Moderator
Staff member
Advanced Member level 7
Bochum, Germany
Bridge rectifiers are sketched with wrong polarity. Diode between capacitor and battery seems useless.
What's the piezo frequency? Most likely explanation is that the actual piezo current is only in a uA range.
KlausST
Super Moderator
Staff member
Something is wrong with your diode orientations.
The bridge rectifiers generate "+" down and "-" top.
But the most right diode is reverse and the battery is reverse.
Please correct this.
(According schematic rules you should draw "+" top and "-" bottom)
How do you come to 50V and 40mA? Did you measre it? How?
What's the frequency?
Klaus
LaTeX Commands Quick-Menu:
