sdouble
Newbie level 2
Hi everybody,
I'm Julien, I'm a nuclear physicist who has to amplify rare pulses (say 1kHz typical repetition rate). The pulse amplitude (50 ohms adapted) vary from 10 to 200 mV and I need to put 20 dB amplification on those pulses. The pulses are negative and exhibit a 1.5 ns rise time and 3 ns decay time, no plateau. The frequencies involved are, I assume ranging from 100 to 500 MHz.
I'm looking for an integrated amplifier which could do the job. Not so easy. to find the proper MMIC EphEMT. My main concern is the noise immunity.
Most have the wrong phase shift or too low P1dB. I was looking for something in the 2-3dB noise figure range. If I could afford the 10 dB noise, I would go for a High GBW op amp (OPA846 for instance).
Would you have any proposal ?
thanks in advance.
thanks in advance.
