Basic query of reset in 8051 uC
Monu johar
Newbie level 5
Newbie level 5
I am using 8051...and burn a programm in it as :-
Code ASM - [expand]
8
9
10
11
12
org 000h
mov tmod,#20h
mov scon,#50h
mov th1,#-3
setb tr1
clr ri
here: jnb ri,here
clr ri
mov a,sbuf
mov p2,a
sjmp here
end
now my query is that if i reset microcontroller from 9th pin..after burning the program...then all ports become input ports...if value in sbuf is 00110101. That should be present on port2 ,as by the code.. Here the port 2 is acting like output port..but on reset it is input port..now i want to know that will the data bits of sbuf come on port pins or not?
For 8051, unlike PIC, the I/O pin is input as long it is 1 (due to its open collector output). Also it acts anytime as an output pin if it is set by the program as 1 or 0.
Notes:
(1) While a pin is set as 0, the pin cannot be used as an input terminal.
(2) Usually when a pin is needed as an output terminal, an external pull-up resistor may be added for its 1 state since its internal pull-up (if it exists) is rather of a high resistance.
