richie244
Newbie level 2
#include <p18f252.h>
I am using MPLAB v8.10 and am trying to innitialise an LCD display and write something to it just to prove I have control pf it via the pic in 8 bit mode. It will bviously be part of a larger program eventualy and I have also written the program for A/D as shown.
At the moment nothing appears on the LCD and I can see where in the program I hae gone wrong. Please help
#include <stdlib.h>
#include <string.h>
#include <delays.h>
void Initial()
TRISA = 0xFF; // port A, all bits, inputs
TRISB = 0x00;
ADCON1 = 0b10000000; //AD port configuration
//AAAAAAAA VDD VSS
ADCON0bits.ADCS1=1;
ADCON0bits.ADCS0=0; // ADC clock = Fsoc/32
ADCON0bits.CHS2 =0;
ADCON0bits.CHS1 =0;
unsigned char readADC(int ch){
unsigned char adcValue;
if(ch == 0) ADCON0bits.CHS0 =0; // select channel 0
else ADCON0bits.CHS0 =1;
ADCON0bits.ADON =1; // turn on ADC
ADCON0bits.GO_DONE = 1; // start conversion
while(ADCON0bits.GO_DONE) // wait for conversion end
adcValue = ADRESH;
return adcValue;
void LcdEnable();
* Display
#define lcd_rs PORTCbits.RC2
#define lcd_rw PORTCbits.RC3
#define lcd_e PORTCbits.RC4
#define lcd_cmd_wri 0x00
#define lcd_data_wri 0x01
#define lcd_busy_rd 0x02
#define lcd_set_function 0x3C //00111100 8 bit interface, 4 line mode, 5x11 dot format
#define lcd_set_visible 0x0F //Display on, cursor underline on, cursor blink on
#define lcd_set_shift 0x16 //Cursor move, Right shift
#define lcd_set_mode 0x06 //Increment, display shift off
#define lcd_set_cgaddr 0x40
#define lcd_set_ddaddr 0x80
#define lcd_clr 0x01
#define lcd_init 0x30
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
int i,j;
const int Twentyms = 640000;
const int Tenms = 320000;
const int Onetwofivems = 4000000;
const int Twohundredus = 6400;
const int Onehundredus = 3200;
const int Sixtyfourms = 2048000;
void WrCmd2Lcd(char cmd);
void WrDat2Lcd(char data);
void InitLcd();
void Speech(char words,int position);
void LcdWait();
void LcdPutPar(int par);
void LcdEnable()
lcd_e=1;
j=Tenms;
for (i = 0; i < j; i++); //delay for 10ms
lcd_e=0;
TRISB = 0x00;
lcd_rw=0;
lcd_rs=1;
PORTB=cmd;
LcdEnable();
TRISB =0x00;
lcd_rw=0;
lcd_rs=0;
PORTB = data;
LcdEnable();
void InitLcd()
lcd_e=0;
j=Onetwofivems;
for (i = 0; i < j; i++); //delay for 125 ms
WrCmd2Lcd(lcd_init);
j=Twentyms;
for (i = 0; i < j; i++); //delay for 20ms
LcdEnable();
j=Twohundredus;
for (i = 0; i < j; i++); //delay for 200us
LcdEnable();
j=Onehundredus;
for (i = 0; i < j; i++); //delay for 100us
WrCmd2Lcd(lcd_set_function);
j=Tenms;
WrCmd2Lcd(lcd_set_visible);
j=Tenms;
WrCmd2Lcd(lcd_clr);
j=Onehundredus;
WrCmd2Lcd(lcd_set_mode);
j=Tenms;
WrCmd2Lcd(lcd_set_ddaddr);
j=Onehundredus;
void LcdWait()
int status;
TRISB=0xFF;
TRISB = lcd_busy_rd;
do
lcd_e=1;
status = ADCON1;
lcd_e=0;
while(status & 0x80); // test busy flag.
char *textptr;
//textptr = words;
WrCmd2Lcd(position);
LcdWait();
j=Sixtyfourms;
for (i = 0; i < j; i++); //delay for 64ms
do
WrDat2Lcd(*textptr);
*textptr++;
while(*textptr != '\n');
TRISBbits.TRISB0 = PORTBbits.RB0,par & 0X01;
TRISBbits.TRISB1 = PORTBbits.RB1,par & 0X02;
TRISBbits.TRISB2 = PORTBbits.RB2,par & 0X04;
TRISBbits.TRISB3 = PORTBbits.RB3,par & 0X08;
TRISBbits.TRISB0 = PORTBbits.RB4,par & 0X10;
TRISBbits.TRISB1 = PORTBbits.RB5,par & 0X20;
TRISBbits.TRISB2 = PORTBbits.RB6,par & 0X40;
TRISBbits.TRISB3 = PORTBbits.RB7,par & 0X80;
void main(void) {
unsigned char voltage1, voltage2;
while(1){
// voltage1 = readADC(0);
// voltage2 = readADC(1);
InitLcd();
// WrCmd2Lcd(0X06);
// LcdEnable();
WrDat2Lcd("A");
// LcdWait();
while(1);
