shlomo22
Member level 4
![Member level 4](/styles/images/ranks/dlevel4.gif)
candence inductance simulation
I'm having two issues with the Cadence/spectre analog enviroment. Perhaps someone more experienced than me can help me solve them?
1) In the schematic: Next to my transistor are three lines of red text. They go as follows:
2) I want to do a s-parameter analysis of this transistor. The simulation runs successfully and then I go to Results->Print->S-Parameter and the s-parameters are displayed. Then I go to Expressions->Edit in the "Results Display Window". It lists the formulas used to display s-parameters, for example "mag(sp(1 1))". Keeping this window open, I then run another simulation, then go back to the results window and choose Window->Update Results. But this fails with the message "*Error* mag: can't handle mag(nil)"! Why doesn't this work? Also, whenever I try to define an output variable in the main analog enviroment window, the simulation fails with a similar message about "nil". What's going on?
The first line is the device model name and the third line is the number of fingers. What does the second line refer to? I see no way of getting rid of this "Error" (when I look at properties everything seems to be OK) but when I run simulations, everything seems to run correctly. Can I just ignore this error?"n18rf"
*Error*
nf=6
