banksel of PIC 16f877a
PA3040
Advanced Member level 3
Dear All,
This is related to 16F877a MCU
As we all aware banksel directive can use to change from bank to bank
Ex
banksel   TRISB
As per above, in front of bansele we must write name of SFR which we belong to the bank.
Now in bank1
Let's we assume now I need to transfer to the bank which PORTB belong
Ex
banksel   PORTB
As we all ware PORTB register exists on two bank ( bank 0 and bank 2).
How can we confirm that above directive belongs to which bank.
Please advice
Thanks in advance
I think it always selects the lowest bank if it has duplicates. It doesn't really matter though, it will work anyway.
As far as I know, all banksel does is copies the most significant bits of the registers address into the bank selection bits so it would use whichever address the assembler was told that register resided at.
Brian.
Reactions: PA3040
    PA3040
Dear betwitx thanks for the reply
from the bank1 I need access PORTB and user define register in bank 2
So I am not sure banksel PORTB whether bank0 or bank2, if it is bank2 i will be easy
Please advice
Thanks in advance
The assembler will look up the address of PORTB in the "16F877A.inc" file. If you look in that file it lists it as:
PORTB            EQU  H'0006'
in the table for bank 0 so that's what it will use.
There isn't a problem using PORTB at the other bank addresses if you redefine it but the easiest way to do what you want is simply to use another banksel directive for the register you defined, for example:
banksel PORTB
<do something with PORTB>
banksel MyRegister
<do something to your user defined register called 'MyRegister'>
Brian.
Reactions: PA3040
    PA3040
