purian
Member level 2
How can i design this amplifier, the bandwidth is about 40MHz~100MHz, P1dB is 15dBm, and the Gain is about 15dB, which circuit topology can I used, is there anyone give me some advice? thanks!:?:
Differential Cascode is also possible with or without feedback.All you have to do is to create a balun at the input of the amplifier for single ended signal sources.I want to used BiCMOS 0.18um PDK, and the differential structure must be used to connect the later circuit, can the cascode configuration with/without feedback is possible? The single chip without any off-chip component is possible? thanks.
