zzm_3392
Junior Member level 2
Dear all,
I am confused with the routing of WE748422245 Balun balanced port impedance. Based on the datasheet, I should design proper line width to provide impedance matching. So the balanced port routing is designed by differential 200 Ohm or by single 100 Ohm. It seems the single 100 Ohm from the datasheet.
Furthermore, the PCB is 4 layers, and the critical line is on the top layer, the reference is Midlayer1. The designed 50 Ohm line refers to the following picture. But there is not suitable line width for differential 200 Ohm. Because the line is too small. Can anyone give me some layer stackup suggestion and the corresponding line widths?
Thanks very much.
Thanks very much.
