nickthamma
Newbie level 5
Why is balancing input of op amps so important? I have read that it enhances performance. In what way is the performance of an op amp affected by balancing the inputs?
Note: This feature currently requires accessing the site using the built-in Safari browser.
It has got nothing to do with the impedance because the impedance looking out of the inverting terminal is zero (Rf/Aopen). But in case of BJT input pair, Rb could be used for input offset cancellation.
Obviously right, but not what the OP is asking for.The impedance looking into the inverting terminal of the closed loop opamp is zero. Any amount of current you pump into that node, its voltage will not change due to virtual ground effect. So delta V/ delta I is zero.
