sreevenkjan
Full Member level 5
Hi all,
I am building a PCIE EP using Ultrascale PCIe IP from Xilinx. I am using 2017.3 Vivado for the design.
Since the ultrascale EP supports only AXI Stream, I need a converter from AXI4 to AXIS, I went through some of the forums and read that people could use AXI-DMA or AXI-Datamover IP to handle both AXI4 to AXIS.
My question is do I need to use a DMA or a Datamover, the PCIe EP would be programmed in a hardware board and would act as a streaming endpoint. Which IP would be suited in this case?
Thanks for your help.
regards,
Sreeni
regards,
Sreeni
