avr programming in AVR Studio and CodeVision
ghoola
Member level 2
Member level 2
india
how can I change this AVR studio code to Codevision code?
 SPCR = _BV(SPE)|_BV(MSTR)|_BV(SPR1)|_BV(SPR0)
The definition of _BV is
#define _BV(bit) (1 << (bit))
so basically your code is
SPCR = (1<<SPE) | (1<<MSTR) | (1<<SPR1) | (1<<SPR0);
If the SPE,MSTR,SPR1 and SPR0 bits are not defined in codevision then check the datasheet and either add the definitions or replace them with numbers.
The datasheet lists all the registers and the names of each bit of the register
The register you refer to is
So if the definition don't exist in codevision you can either add them or replace the bit names with the bit number
I would expect the register names to be already defined.
You can try to compile your code, if any name if undefined you will get an error and then you can fix it.
You can also check the content of the header that codevision attaches in the project (the specific mcu model defines).
Reactions: ghoola
    ghoola
