AVR model bug in Proteus VSM 5.20.7
michu
Newbie level 6
Newbie level 6
Poland
proteus dll avr
There is a serious bug in AVR model in Proteus VSM :!:
It seems that the simulator pushes a return address of CALL instruction with bytes in wrong order, which is difficult to trace because of RET instruction also working that way.
The problem occures when you want to run e.g. AvrX in Proteus VSM env., because of IJMP instructions used in context switching....
Does anyone know if the bug is removed in Proteus 6.0 or how to patch original AVR dll to cure the problem :?:
avr proteus vsm bug
Also in version 5.20.07.
The simulator does not recognise the BLD instruction. It is just executed as a NOP. A way to overcome this bug is to use the CBR or SBR instruction, for T=0 or T=1 resp.
Wonder whether this bug is solved in version 6???
