milan.rajik
Banned
My LCD 4bit code is not working in hardware. Why ? I am using IAR EW AVR 6.60.1 licensed Compiler, ATMega1284 @ 8 MHz external clock and mikroElektronika's EasyAVR v7 development board. I am attaching my IAR AVR project. LCD code is correct because I use that code in other compilers. I think the problem is with
and
functions. How to make a proper Delay function which gives exact delay based on clock frequency ?
IAR EW AVR Code
Delay_us()
Delay_ms()
IAR EW AVR Code
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 #define F_OSC 8000000 #include <iom1284.h> #include <intrinsics.h> #define _LCD_FIRST_ROW 0x80 //Move cursor to the 1st row #define _LCD_SECOND_ROW 0xC0 //Move cursor to the 2nd row #define _LCD_THIRD_ROW 0x94 //Move cursor to the 3rd row #define _LCD_FOURTH_ROW 0xD4 //Move cursor to the 4th row #define _LCD_CLEAR 0x01 //Clear display #define _LCD_RETURN_HOME 0x02 //Return cursor to home position, returns a //shifted display to its original position. //Display data RAM is unaffected. #define _LCD_CURSOR_OFF 0x0C //Turn off cursor #define _LCD_UNDERLINE_ON 0x0E //Underline cursor on #define _LCD_BLINK_CURSOR_ON 0x0F //Blink cursor on #define _LCD_MOVE_CURSOR_LEFT 0x10 //Move cursor left without changing //display data RAM #define _LCD_MOVE_CURSOR_RIGHT 0x14 //Move cursor right without changing //display data RAM #define _LCD_TURN_ON 0x0C //Turn Lcd display on #define _LCD_TURN_OFF 0x08 //Turn Lcd display off #define _LCD_SHIFT_LEFT 0x18 //Shift display left without changing //display data RAM #define _LCD_SHIFT_RIGHT 0x1E //Shift display right without changing //display data RAM void Delay_us(unsigned int uSec); void Delay_ms(unsigned int mSec); void LCD_Cmd(char out_char); void LCD_Chr(char row, char column, char out_char); void LCD_Chr_Cp(char out_char); void LCD_Init(); void LCD_Out(char row, char col, char *text); void LCD_Out_Cp(char *text); void Delay_us(unsigned int uSec) { unsigned int i = 0; while(uSec != 0) { for(i = 0; i < 250; i++); uSec--; } } void Delay_ms(unsigned int mSec) { unsigned int i = 0; while(mSec != 0) { for(i = 0; i < 2000; i++); mSec--; } } #define EN_DELAY 100 #define LCD_STROBE {LCD_EN = 1; Delay_us(EN_DELAY); LCD_EN = 0; Delay_us(EN_DELAY);}; #define LCD_RS PORTA_Bit2 #define LCD_EN PORTD_Bit6 #define LCD_D4 PORTC_Bit4 #define LCD_D5 PORTC_Bit5 #define LCD_D6 PORTC_Bit6 #define LCD_D7 PORTC_Bit7 #define LCD_RS_Direction DDRA_Bit2 #define LCD_EN_Direction DDRD_Bit6 #define LCD_D4_Direction DDRC_Bit4 #define LCD_D5_Direction DDRC_Bit5 #define LCD_D6_Direction DDRC_Bit6 #define LCD_D7_Direction DDRC_Bit7 void LCD_Cmd(char out_char) { LCD_RS = 0; LCD_D4 = (out_char & 0x10)?1:0; LCD_D5 = (out_char & 0x20)?1:0; LCD_D6 = (out_char & 0x40)?1:0; LCD_D7 = (out_char & 0x80)?1:0; LCD_STROBE LCD_D4 = (out_char & 0x01)?1:0; LCD_D5 = (out_char & 0x02)?1:0; LCD_D6 = (out_char & 0x04)?1:0; LCD_D7 = (out_char & 0x08)?1:0; LCD_STROBE if(out_char == 0x01)Delay_ms(2); } void LCD_Chr(char row, char column, char out_char) { switch(row){ case 1: LCD_Cmd(0x80 + (column - 1)); break; case 2: LCD_Cmd(0xC0 + (column - 1)); break; case 3: LCD_Cmd(0x94 + (column - 1)); break; case 4: LCD_Cmd(0xD4 + (column - 1)); break; } LCD_RS = 1; LCD_D4 = (out_char & 0x10)?1:0; LCD_D5 = (out_char & 0x20)?1:0; LCD_D6 = (out_char & 0x40)?1:0; LCD_D7 = (out_char & 0x80)?1:0; LCD_STROBE LCD_D4 = (out_char & 0x01)?1:0; LCD_D5 = (out_char & 0x02)?1:0; LCD_D6 = (out_char & 0x04)?1:0; LCD_D7 = (out_char & 0x08)?1:0; LCD_STROBE } void LCD_Chr_Cp(char out_char) { LCD_RS = 1; LCD_D4 = (out_char & 0x10)?1:0; LCD_D5 = (out_char & 0x20)?1:0; LCD_D6 = (out_char & 0x40)?1:0; LCD_D7 = (out_char & 0x80)?1:0; LCD_STROBE LCD_D4 = (out_char & 0x01)?1:0; LCD_D5 = (out_char & 0x02)?1:0; LCD_D6 = (out_char & 0x04)?1:0; LCD_D7 = (out_char & 0x08)?1:0; LCD_STROBE } void LCD_Init() { LCD_RS = 0; LCD_EN = 0; LCD_D4 = 0; LCD_D5 = 0; LCD_D6 = 0; LCD_D7 = 0; LCD_RS_Direction = 1; LCD_EN_Direction = 1; LCD_D4_Direction = 1; LCD_D5_Direction = 1; LCD_D6_Direction = 1; LCD_D7_Direction = 1; Delay_ms(30); LCD_D4 = 1; LCD_D5 = 1; LCD_D6 = 0; LCD_D7 = 0; LCD_STROBE Delay_ms(10); LCD_D4 = 1; LCD_D5 = 1; LCD_D6 = 0; LCD_D7 = 0; LCD_STROBE Delay_ms(10); LCD_D4 = 1; LCD_D5 = 1; LCD_D6 = 0; LCD_D7 = 0; LCD_STROBE Delay_ms(10); LCD_D4 = 0; LCD_D5 = 1; LCD_D6 = 0; LCD_D7 = 0; LCD_STROBE Delay_ms(10); LCD_Cmd(0x28); LCD_Cmd(0x06); } void LCD_Out(char row, char col, char *text) { while(*text) LCD_Chr(row, col++, *text++); } void LCD_Out_Cp(char *text) { while(*text) LCD_Chr_Cp(*text++); } int main( void ) { DDRA = 0xFF; DDRB = 0xFF; DDRC = 0xFF; DDRD = 0xFF; PORTA = 0x00; PORTB = 0x00; PORTC = 0x00; PORTD = 0x00; LCD_Init(); LCD_Cmd(_LCD_CURSOR_OFF); LCD_Cmd(_LCD_CLEAR); LCD_Out(1,1,"LCD 4bit"); LCD_Out(2,1,"IAR EW AVR"); while(1) { } //return 0; }
