Typical power consumed by a clock tree in the design is around 40-45%
What is the typical or on an average power consumed by combinational logic cells in the design after pnr.
Hi, Thanks for the reply.
I am new to PnR please bear with me , Can you give number of standard cells and macro numbers in your design...What would be the % of power consumed by CT for the design with like 300,000 standard cells and around 100 macros. I saw in few designs the CT power was around 40-45% and I assumed this is common trend cuz maximum switching activity ll be in clock tree compared to other parts.
Whats the main factor which decides power consumed by CT compared to total power ?
It's all about transition density, and gate by gate this is
widely variable.
Clock tree vs total, that's architectural. How much is
always-clocked registers / FFs, how much is gated-
clock, how much is combo logic? Nobody's answer
will be the same as yours, unless their chip design
is the same as yours. Assessing the similarity of
basis, for any answer you get, is on you.
widely variable.
Okay, we can make a design which can consume wide range of CT power It depends on all these factors but typical IC blocks have on an average certain % of combinational cells and certain % of registers and hard macros, can't we assume in general in designes used in industry CT ll consume almost 50% of power , cuz I read same thing in multiple sources.
Example:
" clock network is responsible for more than half the power consumed on any chip " this is from the source https://semiengineering.com/the-trouble-with-clock-trees/
If not, I don't understand why here it is assumed that CT consumes more-than 50% of total power.
Guys, please, have some level of critical thinking. Of course 50% is not always the case.
Clock trees can be the bottleneck of your design, or it can be a meaningless blip on the radar. We can talk about CTS and its goals (slew, delay, skew). If you have relaxed goals for these, then your clock tree is going to be very easy.
