Automated Hematology Analyzer
hindawi
Newbie level 5
automated hematology analyzer
Hi all
I need the designing project for Automated Hematology Analyzer for counting blood cells
The count principle of the instrument ( analyzer ) is based on the measurement of changes in an electrical resistance produced by a particle passing through line .
hindawi
Newbie level 5
hematology automated principle
Thanks for your kind support.
I'd like to give you more details about the concept of the instrument way of working :
a) The blood cells are non-conductive, the
diluent is a good conductor
b) we add liquid to blood
c) The sample blood is diluted in a conductive liquid. There are big differences between them.
e) we measure carrier
ark5230
Advanced Member level 3
India
May please add information as regards resistance, range and the flow part. Else others are based on image processing from microscopic images and cell size, layer thickness etc.
bobcat1
principle of automated hematology analyzer
Hi
You can use AD5933 impedance analyzer - IC designed to measure impedance
you can measure the liquid impedance (liquid dose not have to be conductive - have DC resistance) to know the number of blood cell with in
All the best
Bobi
hindawi
Newbie level 5
principal of working of hematology analyzer
Thanks for replay
I will check it and tell you later
pranam77
Advanced Member level 5
INDIA
what is automated hematology analyzer
a) The blood cells are non-conductive, the diluent is a good conductor
Shall expect answeres to these questions below?
1. When Dilutant is addded, is there any formula for adding a specific amount to certain amount of blood? For example if we have 1ML of blood, what quantity of dilutant is added to the same to measure it.
2. Does dilutants from various companies have the same conductivity?
3. Is a commercial analyser available or you are planning something different?
Good luck
hindawi
Newbie level 5
diluent hematology
We know exactly the amount of diluent which should be added.
And we used the same diluent from one company .
The problem is not this .
The problem is how we measure more results from one sign ?
I am planning for a good quantity analyzer
Look to picture in file
