autobauding in lpc2148
shubh1994
Member level 1
Member level 1
I was able to erase and program lpc2148 before loading this code,after i loaded this code which i have attached, the problem of autobauding is started.
I loaded main.hex in lpc2148
3.3v power supply is constant
i connected 11.0592 crystal and two 33pf capacitors,
for rtc 32.768 crystal with 10pf capacitor,
connected all vdd,vadd to 3.3v directly,
connected all vss,vass to ground,
i am using max232 for programming.
P0.14 is connected with pull up resistor(10K).
Please help:-(
awaiting for reply!!
CODE::
* WinARM Demo P0.16 blink
#include "types.h"
#include "LPC214x.h"
#include "config.h"
#include "armVIC.h"
#define IOPINS016 16
* Function Name: lowInit()
* Description:
* This function starts up the PLL then sets up the GPIO pins before
* waiting for the PLL to lock. It finally engages the PLL and
* returns
* Calling Sequence:
* void
* Returns:
* void
static void lowInit(void)
// set PLL multiplier & divisor.
// values computed from config
PLLCFG = PLLCFG_MSEL | PLLCFG_PSEL;
// enable PLL
PLLCON = PLLCON_PLLE;
PLLFEED = 0xAA; // Make it happen. These two updates
PLLFEED = 0x55; // MUST occur in sequence.
// setup the parallel port pin
IO0CLR = (1<<IOPINS016); // clear the ZEROs output
IO0SET &= ~(1<<IOPINS016); // set the ONEs output
IO0DIR =(1<<IOPINS016); // set the output bit direction
// wait for PLL lock
while (!(PLLSTAT & PLLSTAT_LOCK))
continue;
// enable & connect PLL
PLLCON = PLLCON_PLLE | PLLCON_PLLC;
// setup & enable the MAM
MAMTIM = MAMTIM_CYCLES;
MAMCR = MAMCR_FULL;
// set the peripheral bus speed
// value computed from config.h
VPBDIV = VPBDIV_VALUE; // set the peripheral bus clock speed
static void sysInit(void)
lowInit(); // setup clocks and processor port pins
// set the interrupt controller defaults
#if defined(RAM_RUN)
MEMMAP = MEMMAP_SRAM; // map interrupt vectors space into SRAM
#elif defined(ROM_RUN)
MEMMAP = MEMMAP_FLASH; // map interrupt vectors space into FLASH
#else
#error RUN_MODE not defined!
#endif
VICIntEnClear = 0xFFFFFFFF; // clear all interrupts
VICIntSelect = 0x00000000; // clear all FIQ selections
VICDefVectAddr = (uint32_t)reset; // point unvectored IRQs to reset()
static void _delay(uint32_t N)
for (uint32_t i=0; i<N;i++);
int main(void)
sysInit();
for (;;)
_delay(900000);
IO0SET = (1<<IOPINS016); // set the ONEs output
_delay(900000);
return 0;
