Audio mic AGC circuit before codec
ahgu
Full Member level 3
Full Member level 3
audio agc circuit
Does anyone has a simple yet effective AGC for MIC amplification before the signal goes to the codec?
I don't want the signal to saturate, but amplify about 30-40dB if possible for weak signals.
thanks
ahgu
mic agc
You can use the SSM2165, SSM2166 or SSM2167 Microphone Preamplifier with Variable Compression and Noise Gating from Analog Devices.
simple agc circuit
thanks
ahgu
you may check the INA163 datasheet form BurrBrown/TI. The datasheet
contains some mic examples, but no AGC.
usbman
agc circuit
microphone agc
There is no compressor function in the circuit you linked to Hishamsaleh.
microphone agc circuit
I found one, working very nice.
Can u post that circuit that worked for you? PLz... ahgu
