waqas5304
Member level 1
Hi
U1 and U7 are the instrumentation amplifiers (INA163UA). U1 and U7 are supplied with + 15 V all the time .U1 & U & are two different microphone circuits.S1 And S2 are two different Audio amplifiers SSM2211. Both drive headphones.S1 has 5 Volts as power supply all the time whereas S2 is switched On / Off by switch in 5 volt supply path. Both the circuits shown in diagrams are on same PCB.
Problem:
When the microphone (5 ohms symmetrical) is plugged in input of U1, the signal from this circuit should not be audible is headset at S2. But I can hear distorted signal in headset at S2. Visa versa When the microphone (5 ohms symmetrical) is plugged in input of U7, the signal from this circuit should not be audible is headset at S1. But I can hear distorted signal in headset at S1.
When the SSM2211 S2 is powered OFF, the problem is solved. As soon as the S2 is powered on the same problem comes again.
I thought that the problem is due to the Power supply than I separated the powers supplies of both Audio Amplifier S 1 & S2 but the problem is still there.
Is this the cross talk or some ground loop problem ?
I hope you can tell me the solution. Thanks in advance
The circuits are attached as attachment
waqas
Problem:
waqas
