Audio Amplifier using LM386
devilgod
Junior Member level 2
Hi frnds, i want to make an audio amplifier. I bought a lm386ic too. but when i searched ckt diagrams mostly using electrolytic capacitor that i dont have...I only have 10uf and 100uf elect capacitor so can anybody provide some other ckt which use these capacitors...or any other like ceramic ones..
The 386 is among the most popular ICs to use for a low power audio amp. It was designed to be easy to use.
The datasheet specifies a large capacitor at the output when you use a single supply. This is so DC will be blocked, but bass frequencies will be carried adequately.
You can still get output if you install your 100uF. However the bass won't be quite as strong as it would be with a 1000 uF.
Your 10uF will work at the other spot where a smaller value is specified in the schematic.
Sounds like you could use an assortment of capacitors to put in your projects. Electronic parts are cheaper if you go the mail order route instead of the local Radio Shack.
Recently I ordered computer grade capacitors from the CAP King. I couldn't believe his low prices. Shipping is free. (If you live in the US that is. For international customers he adds $5.)
Compare that to the ridiculous shipping charges for a tiny order that any other mail order house will tack on.
Link:
Computer Capacitors
so can anyone provide simple ckt...
