dk
Junior Member level 1
hi
i have been using atmel AT89C51ED2 microcontroller . the problem i am facing
is that i can make toggle port 0 pins (open drain outputs, with external pull ups,
but i have beev not able to toggle or rather make other port pins low specifiaclly
those ports that have internal pull ups.
1) i have disabled the internal pull up thru software
2) i gave the ports pins external pull ups but still i cant lower the port pins ,
as per datasheet this port pins with internal pull ups are quasi bidirectional ports
the ports pins toggles mometarily , it can send data bursts but but doesnt go to low state even if the software commands it do so.
Can any one help me
Can any one help me
