Atmel Dataflash AT45DB041B: Anyone used them b4?
irfansyah
New South Wales
dataflash avr butterfly
Hi
I found a cheap serial DataFlash(R) from Atmel : AT45DB041B. Only about $4. It has 512kbyte of memory, and 264 byte on each page.
Anyone here ever used them? I noticed that this Dataflash is also used in Atmel AVR Butterfly. I need to know how to use them using AVR-GCC. Anyone knows?
It uses low voltage (3volts), but accepts 5 volts input (but doesnt output 5 volts logic).
Thanks.
Use the db161b before, unsuccessfully. Never really spend time to trouble shoot it. Anyway, the only reminder is that you should take note of the available package. The last time i use the tsop, and it really need gentle handling,
rgds,
cf
