abdoalghareeb
Member level 5
I'm trying to build 192x24 dot matrix disply,I use atmega8 and AVR codevision compiler.
the following is not the main program,but my problem in this simple code is the same.
I have three matrix for three images and one buffering matrix.
when I make build & compile the next message appears with NO ERRORs.
but after adding this line
image_buffer[n]=image1[n];
this error appeared
Linker error: global RAM variables size: 1152 bytes is too large
#include <mega8.h>
unsigned int n=0;
unsigned char image_buffer [576] = {0x55, 0x55, 0x05, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C };
const unsigned char image1 [576] = {0x55, 0x55, 0x05, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C };
const unsigned char image2 [576] = {0x55, 0x55, 0x05, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C };
const unsigned char image3 [576] = {0x55, 0x55, 0x05, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xFF, 0xFF, 0x0F, 0xFD, 0xFF, 0x0F, 0xF1, 0xFF, 0x0F, 0xC1, 0xFF, 0x0F, 0x01, 0xFF, 0x0F, 0x01, 0xFC, 0x0F, 0x01, 0xF0, 0x0F, 0x01, 0xC0, 0x0F, 0x01, 0x00, 0x0F, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C, 0x01, 0x00, 0x0C };
void main(void)
while (1)
if (~PINB.0)
for(n=0;n<575;n++)
//image_buffer[n]=image1[n];
this error appeared
