sivakumar_tumma
Full Member level 4
I tried a simple program in the Atmega8 board for flashing LED. Initially , when I programmed, the internal clock of 1MHz was used. The LED was flashing.
Then I changed to 2MHz,4MHz and 8MHz. The speed at which LED blinking was fast.
Then I wanted to try with external crystal. But the crystal I used was 12MHz (I thought over clocking may work here). When I flashed the fused using AVRDUDE, nothing happened. So, I disconnected and powered up the board. Now also , the LED was not blinking. Now when I connect the AVRDUDE programmer, the device is not detected which was happening previously. Now, I am not able to erase the fuse settings as device is not detected by AVRDUDE.
Can anyone suggest, how to come out of this situation ?
Regards,
Siva.
Regards,
Siva.
