Alex Aldridge Arabaolaza
Newbie level 2
Hi mates. I'm really stuck trying to communicate both ATMega644P controller and a Cirrus Logic CS5460A power meter. I've read the datasheet carefully several times but I haven't been able to solve the problem yet. My problem is that the MISO line is always 0. I leave the code i use just in case you notice any kind of error.
Atmega644P is running @20Mhz while CS5460A is running @3.6864Mhz.
SPI initialization in ATMEGA644P:
Then I initialize the CS5460A by sending these commands:
And then, to retrieve data from CS5460A i use this code:
I know the MISO line is always 0 as I looked carefully into it using an oscilloscope. The rest of the lines seem to be working fine. Do you have any idea about what can be going on?
* Initialize and configure the SPI
* SPI Type: Master
* SPI Clock Rate: 1,25MHz
* SPI Clock Phase: Cycle Half
* SPI Clock Polarity: Low
* SPI Data Order: MSB First
__C_task void InitSPI(void)
SPCR0= (1<<SPE0) | (1<<MSTR0) | (1<<SPR00);
SPSR0=0x00;
SPI_initialized = TRUE;
void init_CS5460A_send_sequence(){
CLRBIT(CS5460A_SS); //Enable CS5460A
for(int i = 0; i < 20000; i++);
//Send Synchronization commands
cs5460_sync();
//soft reset
cs5460_Write_data(CONFIG_REGISTER, 0x000080);
//Resync
cs5460_sync();
//configure (x10 gain for current)
cs5460_Write_data(CONFIG_REGISTER, 0x000061);
//set integration period (72 clocks)
cs5460_Write_data(CYCLE_COUNT_REGISTER, 0x000048);
//reset all bits in status register (IC* bit ignored)
cs5460_Write_data(STATUS_REGISTER, 0xFFFFFF);
//set DRDY in mask register (for INT*)
cs5460_Write_data(MASK_REGISTER, 0x800000);
//start continuous computation cycles
cs5460_send(0xE8);
SETBIT(CS5460A_SS); //Disable CS5460A
CLRBIT(CS5460A_SS);
cs5460_sync();
cs5460_rst_st_reg();
cs5460_Read_data(0x18);
SETBIT(CS5460A_SS);
