Pheetuz
Full Member level 3
Hi Folks,
I am trying to use the Flash Controller in the AT32 series of devices but not having a lot of luck - I have tried using the demo project but that only works intermittently (like very intermittently) occasionally setting the correct memory locations but most of the time doing nothing unless I am writing into the user page where it works consistently.
I decided to move away from using the demo application and do something a little more bare bones and have come up with this:
Which I have seen once set the value at the desired memory location to the value 4! Exciting! It seems that this basic code is suffering the same problem as the demo code provided by Atmel - does anyone have any idea why this would not be working as expected?
I am using the AT32UC3C-EK development board so doubtful that it is a hardware cause!
Thanks,
Pete
int main(void)
/* Points to FLASH */
uint32_t *mem = (uint32_t*)0x8007F000;
uint16_t pageNumber = 0;
avr32_flashc_t * temp = &AVR32_FLASHC;
// Switch main clock to external oscillator 0 (crystal).
pcl_switch_to_osc(PCL_OSC0, FOSC0, OSC0_STARTUP);
/* Clear the page buffer. */
AVR32_FLASHC.FCMD.cmd = 3;
AVR32_FLASHC.FCMD.key = 0xA5;
/* Read with a single wait state. */
AVR32_FLASHC.FCR.fws = 1;
pageNumber = AVR32_FLASHC.FCMD.pagen;
*mem = 4;
/* Write page. */
AVR32_FLASHC.FCMD.cmd = 1;
Thanks,
Pete
