Hi everyone,
I've got a problem with Assura LVS. I don't understand why all of my digital circuits which used to pass LVS can't pass now. The process I use is IBM 65nm, they just updated the new PDK, so I thought it is due to the new PDK. However, when I used the old PDK that I had used before, it still didn't pass.
The mismatch is about the Drain and Source of the FET. For example, with a simple transmission gate consisting of 1 PMOS and 1 NMOS, in schematic, what we normally do is: the PMOS' S is connected to the NMOS' D as input, and the PMOS's D is connected to NMOS' S as output. In the layout, the 2 FETS are drawn correspondingly. Previously, this circuit had no problem, but recently, the mismatch came, it told me to swap the NMOS' S and D. I did and it passed. This happens to almost all the digital gates, it usually tells me to swap the FETs, even for a PMOS, what we normally do is connect the Source to VDD, but it tells to swap.
One more weird thing is that one circuit with the same PDK, the LVS passed, then 15' later it didn't, without any change.
Has anyone experienced this? I'm using Cadence 6.1.3 (on grid), Assura 3.2, IBM 65nm Lpe.
Thanks
