iamvictor
Newbie level 1
I am using ASSURA within IBM cms9flp design kits.
1. There is no problem with DRC and LVS, but the extracted view generated by DRC only have all the pins in the view, and no component at all!
If it passed the LVS, I believe the extraction should be correct. So is this the display problem or something else?
2. If I use RCX I can get the extracted view. All parastic R & C are shown with reasonable values, but the parameters with components didn't correspond to the layout parameters.
For example: if I check the extracted transistor symbol porperty, the W was always the minimum size no matter how I double it in the layout. The same for VNCAP, I use M1-M6 in the layout, but if I check the cap symbol porperty in the extracted view, it was M1-M1.
I guess, all the extracted components were all with parameters of stardard cell (minimum size). Also, the "view name" in the "porperty tab" of these components are "symbol" instead of being "auLVS" or "vipcell". If should not be like this.
Could anyone give me a clue?
Many thanks!
Victor
Many thanks!
Victor
