Assembly language instruction
eeHassan
Member level 2
Lahore, Pakistan
what is the minimum size of MOV instruction in assembly language?
1 byte or 2 bytes?
eeHassan,
I am sure it would depend on the processor and on the particular MOV instruction. Most processors will allow you to move bytes, but some are 2 byte minimums. Which processor are you looking to use?
Sckoarn
hi
which controller you are asking about?
almost all processors i know have a MOV instruction in their assembly set
ml
4 clock cycles
---------- Post added at 22:34 ---------- Previous post was at 22:31 ----------
answer also depends addressing mode used...
---------- Post added at 22:35 ---------- Previous post was at 22:34 ----------
