gatobx
Newbie level 1
Greetings from Mexico
Can you help please with ASM or C code to use the Time Keeper Maxim DS3232 with PIC16F and PIC18F micros.
It is noteworthy that the DS3232 is better, much more accurate, does not require of 32.768 kHz XTAL because it has integrated into the package and is replacing the DS1307. The trouble is that no code on the web instead of the DS3232 and if there is enough code for the DS1307.
The DS3232 is very very accurate with only + / - 1.0 to 1.8 minutes of delay or advance the Year. The DS1307 is not very accurate with + / - 5 to 10 or more minutes of delay or advance the month, a year might be a fault of 1 hour or more.
Datasheet:
http://datasheets.maxim-ic.com/en/ds/DS3232.pdf
If you use MSN Messenger and if you want you can add my email to your account: gatobx@gmail.com
Thank you very much for your valuable HELP.
Datasheet:
