triquent
Full Member level 3
1)the expression"(a+b<<1)" and "a+(b<<1)" will be sythesized to the same circuits when a, b is more than 1 bit?
2)Is it always better to let synthesis too decide when to use resource sharing based on design constraint?
3)will the unused input be tied by synopsys design compiler automatically?
4) Does the gated clock refer to a clock network that contains Boolean functions other than buffers and inverters in synopsys design compiler?
and Does teh gated clock network have to be explicitly defined in synopsys design compiler?
5)Must the derived clocks be specified explicitly for synthesis in synopsys design compiler?
