[ask] RS232 to Ethernet
afnindar
Junior Member level 1
rs232 to ethernet diy
How the design if i will build the Converter from RS232 to Ethernet?
what device which i need to develop them?
thanks
diy ethernet to rs232
hi
see the link below.
i think it will help u
have a nice day
salam
Ahmed
https://www.i-g.org
diy rs232 to ethernet
I've used the XPORT from lantronix. It works ok. https://www.lantronix.com/pdf/XPort_DS.pdf
what ever approach you take, you should be aware that all the ethernet modules require a suprising amount of power. Usually > 200mA. A clean power system that can deliver the current is critical. I built one using a linear and had real heat problems. I'd use a switcher instead.
Phil
diy rs232 over ethernet
How if i want to DIY (Do it your self) make a self prototyping PCB and Design?
as **broken link removed**?
regards
diy rs232
the datasheet is very detailed.
