ask > how to setting up a relay on / off during certain hours(digital clock)
Li_ereunpisan
Full Member level 5
Bandung, Indonesia
how to set your alarm be applied to the relay ... example: at the time at 05.00 am at the relay ON and relay OFF at 05.00 pm
  • clock.zip
use a timer interrupt(set it at 5) for 12hrs..
it will simply flip the previous state..if it was on at 5am then it will gt switched off at 5pm..and so on..
or
u may use real time clock and then then check the data and make the further program ....
I agree with beyondH.
In your case wanditea, your schematics it is simply. If you want to keep simply, use digital clock (timer interrupt). You must write some code lines and defined digital clock, because timer which you have in microcontroller could not count hours, but you do not need change the board.
Of course, you must set up digital clock, but you have tasters and LCD on board already, and you can use that elements for set up of digital clock.
or
thx for responbility....
please explain in detail how to write programs with source code that I attach ... please help me edit the source code (asm) which I attach to a program that I expect ...
luk first of all,, i want to say that check if for your controller interrupts are supported or not(if not just simply replace your controller with another one of same family having timer interrupts)..
so, you may proceed as follows:(just the basic structure bcz. assembly may differ with the controllers)
1. set the timercontrol and timer mode registers as per your need..
2. initialise the timer..for exact calculations::ex--if ur timer is of 16bit.. i.e. a max. of 65536 then initiallise the timer register with something like 15536 so as to make a difference of 50k..
3.now your interrrupts are called everytime the timer is filled up(better use in auto reload mode)
4.everytime interrupt is called make ur interrupt handler jump to your made subroutine..now there:: make a variable increment everytime and check for it...(i.e. check when that variable is 20 then that means 50K*20=> 1 sec is over)
5. elongate the concept for again multiplying it with 60*60*12..
hope it helps..
Why u r using LCD and realtime clock for this purpose( relay on/off).Just use one of ur timer for setting up clock and 4led display for showing time and alarm setting. I have done this project for automatic street light controller in PIC micro which runs on 3.6v NiCd battery.
Your circuit might be wrong. It is valid only if you use VERY low power reed relay with integrated diode which you can switch directly from microcontroller. If it's a normal relay then you need to drive it via some driver stage (like an N-MOS transistor) and add a reverse diode across coil terminals to protect the circuit from back emf created by coil when it is being switched off
@beyondh
if the theory is true, but when writing rutin programs confused .. if you can edit the programs that I attach??
thx
@sajeev
because the project is in great need of LCD as the display clock, to know the tool I'm running and every hour of 05:00 pm on ... 05.00pm relay relay off .. if not using the LCD, how can I see the clock ..
@tpetar
of course I use this circuit...
@poorchava
I understand with your intended ... but for me, it could be done later. because what matters most to me is the program(souce code)
thx for all
I think that some bright LED 7-segment display would be better because it is more easily readable. LCD is very angle dependant. Plus with 7-segment displays you can get digits much, much bigger than with lcd.
but I need the appearance of small, so not too visible to the user, because the tool is only in the setting by our technicians
I agree with Poorchava in case of LED display. 4 Led displays can be used to show Hour and Minutes. But if u want to use LCD display u can use 16X2 line lcd display and interface with DS1307 RTC and pic. The routines in C can be downloaded from the microchip website and u can edit it as your wish according to your circuit
sajeev
I want to change the setting alarms to alarm every day
alarm 2x in 1 day, (at 05.00 pm relay on and at 12.00 am relay off)
so I do not need setting up again repeatedly
please help me edit this program to be I want
hold macro
	nop
	nop
	nop
	nop
	endm
disp_str macro string				;Macro for sending string to LCD
	irpc char, <string>
		if nul 'char'
			exitm
		endif
		mov a,#'char'
		lcall data_in
	endm
	endm
build_char macro P1,P2,P3,P4,P5,P6,P7,P8	;Macro for building a custom character
	irp arg, <P1,P2,P3,P4,P5,P6,P7,P8>
		mov a,#arg
		acall data_in
	endm
	endm
	sec equ 30h				;second register
	min equ 31h				;minutes register
	hour equ 32h				;hour register
	days equ 33h				;days register
	date equ 34h				;date register
	month equ 35h				;month register
	year equ 36h				;year register
	alarm equ 37h				;alarm register
	sig equ 38h				;signature for data checking in RTC RAM
	ahour equ 39h				;alarm hour register
	amin equ 3Ah				;alarm minute register
	sda equ P1.1				;Serial data pin
	scl equ P1.0				;Serial clock pin
	rw equ p3.6				;read write pin of LCD
	en equ p3.5				;enable pin of LCD
	rs equ p3.7				;register select pin of LCD
	alarm_key equ p3.3			;Alarm set key
	time_key equ p3.2			;Time ser key
	increment equ p1.3			;Increment value
	decrement equ p1.2			;Decrement Value
	[COLOR="#FF0000"]relay equ p1.4                          ;plisss edit to daily alarm[/COLOR]
	alarm_flag equ 20h			;flag for alarm
	time_flag equ 21h			;flag for time
	ampm_flag equ 22h			;am/pm flag
	alarm_on equ 23h			;Alarm on flag
	alarm_off equ 24h			;alarm off flag
	alarm_ring equ 25h			;alarm ring flag
	alarm_hrs equ 58h			;Alarm hour register
	alarm_min equ 59h			;Alarm Minutes register
	alarm_chk_hour equ 5Ah			;Alarm hour check register
	alarm_chk_min equ 5Bh			;Alarm min check register
	ampm equ 61h				;AM/PM register
	BELL equ 7h				;Bell icon
	SPEAKER_OFF equ 1h			;speaker off icon
	SPEAKER_ON equ 2h			;speaker on icon
	CLOCK equ 3h				;clock icon
	OK equ 4h				;ok icon
	HEART equ 5h				;heart icon
	MUSIC equ 6h				;music icon
	org 0000h				;Starting of main program
	ljmp start
	org 03h					;interrupt for set time
	setb time_flag
	reti
	org 13h					;Interrupt for set alarm
	setb alarm_flag				;and switch off the alarm if on
	jb alarm_off,trs
	ajmp hmmm
trs:
	setb alarm_port
	setb relay
	mov a,#1h
	lcall command  ;parentah lcd
	mov a,#81h
	lcall command
	mov a,#OK
	acall data_in	  ;kirim data lcd
	mov r7,#35
	disp_str < T M Off!>
	setb tr0
loooop:
	jnb tf0,$
	clr tf0
	djnz r7,loooop
	clr tr0
	mov a,#1h
	acall command
	acall disp_const
	setb alarm_off
	setb alarm_on
	clr alarm_flag
	clr alarm_flag
	clr alarm_on
	setb alarm_port
	setb relay
	clr alarm_off
	clr alarm_flag
	clr alarm_ring
hmmm:	reti
start:
	;clear RAM
	mov R0,#7FH
	clr A
clr_ram:
	mov @R0,A
	djnz R0, clr_ram
	;Init I2C Port
	lcall i2cinit
	mov tmod,#1h				;start routine
	mov sp,#10h
	acall initial
	acall build
	mov a,#80h
	acall command
	mov a,#CLOCK
	acall data_in
	disp_str < T M Create by RnD >		;Name display
	mov r7,#50
	;disp_str < Create by RnD >		;Name display
	;mov r7,#50
	setb tr0
wloop:
	jnb tf0,$
	clr tf0
	djnz r7,wloop
	clr time_flag
	clr alarm_flag
	clr alarm_on
	clr ampm_flag
	setb alarm_port
	setb relay
	lcall startc				;Reading invalid hour entry
	mov a,#0d0h					;initialize the RTC if necessary
	lcall send
	lcall ack
	mov a,#02h
	lcall send
	lcall ack
	lcall rstart
	mov a,#0d1h
	acall send
	acall ack
	acall read
	acall nak
	acall stop
	anl a,#1fh
	cjne a,#12h,step
step:
	jnc done
	acall startc				;Reading signature byte if same then no need
	mov a,#0d0h					;of initialization else initialize the RTC
	acall send
	acall ack
	mov a,#08h
	acall send
	acall ack
	acall rstart
	mov a,#0d1h
	acall send
	acall ack
	acall read
	acall nak
	acall stop
	cjne a,#'~',done
	sjmp run
done:
	;acall initial
	;acall disp_const
	mov sec,#00h				;For more information about the RTC DS1307
	mov min,#0h				;Please refer to the datasheet
	mov hour,#52h				;21h for 24 hour format
	mov days,#01h
	mov date,#1h
	mov month,#1h
	mov year,#06h
	mov alarm,#0
	mov sig,#'~'
	mov ahour,#0
	mov amin,#0
	mov r6,#0bh
	mov r0,#sec
	mov r1,#00h
	acall rtc_ini				;initializing RTC if required
run:
	mov ie,#85h
	acall initial
	acall disp_const
run1:
	acall startc				;Actual Starting
	mov a,#0d0h
	acall send
	acall ack
	mov a,#00h
	acall send
	acall ack
	mov r6,#0fh
	acall rstart				;Reading the RCT content
	mov a,#0d1h
	acall send
	acall ack
	mov r0,#40h
here:
	lcall read
	mov @r0,a
	inc r0
	cjne r6,#1,sendack
	acall nak
	sjmp naksent
sendack:
	acall ack
naksent:
	djnz r6,here
	acall stop
	acall display				;Display RTC
	jnb time_flag,noset			;check for time flag if set the set the clock
	clr time_flag
	clr ea
	acall time_set
	clr time_flag
	mov r6,#09h
	mov r0,#30h
	mov r1,#00h
	acall rtc_ini
	clr time_flag
	mov a,#1h
	acall command
	mov a,#81h
	acall command
	mov a,#OK
	acall data_in
	clr time_flag
	disp_str < set waktu >
	mov r7,#35
	setb tr0
looooop:
    jnb tf0,$
	clr tf0
	djnz r7,looooop
	clr tr0
	mov a,#1h
	acall command
	acall disp_const
	setb ea
noset:
	jnb alarm_flag,noset1			;check for alarm flag if set then set alarm
	clr alarm_flag
	clr ea
	lcall alarm_set
	setb ea
	setb alarm_on
	clr alarm_flag
	setb alarm_on
noset1:
	jnb alarm_ring,noset2			;check if alarm ring flag is set
	[COLOR="#FF0000"]clr relay			;plis edit to daily alarm[/COLOR]
noset2:	ljmp run1				;Do everything again
;Initializing I2C Bus Communication
i2cinit:
        setb sda
        setb scl
        ret
;ReStart Condition for I2C Communication
rstart:
        clr scl
        setb sda
        setb scl
        clr sda
        ret
;Start Condition for I2C Communication
startc:
        setb scl
        clr sda
        clr scl
        ret
;Stop Condition For I2C Bus
stop:
        clr scl
        clr sda
        setb scl
        setb sda
        ret
;Sending Data to slave on I2C bus
send:
        mov r7,#08
back:
        clr scl
        rlc a
        mov sda,c
        setb scl
        djnz r7,back
        clr scl
        setb sda
        ret
;ACK and NAK for I2C Bus
ack:
        clr sda
        setb scl
        clr scl
        setb sda
        ret
nak:
        setb sda
        setb scl
        clr scl
        setb scl
        ret
;Receiving Data from slave on I2C bus
read:
        mov r7,#08
back2:
        clr scl
        setb scl
        mov c,sda
        rlc a
        djnz r7,back2
        clr scl
        setb sda
        ret
recv:						;Recieving data from I2C bus
	lcall read
	lcall ack
	mov @r0,a
	inc r0
	ret
rtc_ini:
    acall startc				;RTC initialization subroutine
	mov a,#0d0h
	acall send
	acall ack
	mov a,r1
	acall send
	acall ack
rtc_ini_loop:
	mov a,@r0
	acall send
	acall ack
	inc r0
	inc r1
	;acall stop
	djnz r6,rtc_ini_loop
	acall stop
	ret
initial:
    mov a,#38h				;LCD initialization subroutine
	acall command
	mov a,#0ch
	acall command
	mov a,#01h
	acall command
	mov a,#06h
	acall command
	ret
build:
	mov a,#40h				;Building custom character routine
	acall command
	build_char 0h,0h,0h,0h,0h,0h,0h,0h	 ;BELL
	build_char 17h,4h,14h,17h,14h,14h,14h,0h      ;relay off   1h,3h,0fh,0fh,0fh,3h,1h,0h	 ;SPEAKER OFF
	build_char 13h,15h,19h,0h,1fh,1h,2h,0h      ;relay on    8h,10h,0h,18h,0h,10h,8h,0h	 ;SPEAKER ON
	build_char 0h,0eh,15h,17h,11h,0eh,0h,0h	 ;CLOCK
	build_char 0h,1h,3h,16h,1ch,8h,0h,0h	 ;OK
	build_char 0ah,1fh,1fh,1fh,0eh,4h,0h,0h	 ;HEART
	build_char 2h,3h,2h,0eh,1eh,0ch,0h,0h	 ;MUSIC
	build_char 0eh,11h,1fh,0h,1fh,2h,1fh,0h ; aink        4h,0eh,0eh,0eh,1fh,0h,4h,0h	 ;BELL
	ret
display:
    mov r1,#40h				;Displaying RTC content
	mov a,#0Cah
	acall command
	mov a,@r1
	mov 50h,@r1
	acall disp_val
PASS:
	inc r1
	mov a,#0C7h
	acall command
	mov a,@r1
	mov 51h,@r1
	mov alarm_chk_min,@r1
	acall disp_val
PASS1:
	inc r1
	mov a,#0c4h
	acall command
	mov a,@r1
	mov 52h,@r1
	mov alarm_chk_hour,@r1
	mov r4,a
	anl a,#1fh
	acall disp_val
	mov a,r4
	anl a,#20h
	cjne a,#00h,pm
	mov a,#0cdh
	acall command
	disp_str <am>
	sjmp pass2
pm:	mov a,#0cdh
	acall command
	disp_str <pm>
PASS2:	inc r1
	mov a,#80h
	acall command
	mov a,@r1
	mov 53h,@r1
	acall day
PASS3:
	inc r1
	mov a,#88h
	acall command
	mov a,@r1
	mov 54h,@r1
	acall disp_val
PASS4:
	inc r1
	mov a,#8bh
	acall command
	mov a,@r1
	mov 55h,@r1
	acall disp_val
PASS5:
	inc r1
	mov a,#8eh
	acall command
	mov a,@r1
	mov 56h,@r1
	acall disp_val
	jnb alarm_on,PASS6
	inc r1
	inc r1
	inc r1
	mov a,@r1
	cjne a,52h,PASS6
	inc r1
	mov a,@r1
	cjne a,51h,PASS6
	setb alarm_ring
	setb alarm_ring
PASS6:	ret
disp_val:					;Display 8-bit Decimal Value
	push acc
	mov r5,a
	anl a,#0f0h
	swap a
	mov dptr,#ascii
	movc a,@a+dptr
	acall data_in
	mov a,r5
	anl a,#0fh
	movc a,@a+dptr
	acall data_in
	pop acc
	ret
disp_const:					;Display constant characters
	mov a,#8ah
	acall command
	mov a,#'/'
	acall data_in
	mov a,#8dh
	acall command
	mov a,#'/'
	acall data_in
	mov a,#0c6h
	acall command
	mov a,#':'
	acall data_in
	mov a,#0c9h
	acall command
	mov a,#':'
	acall data_in
	mov a,#0c0h
	acall command
	mov a,#BELL
	acall data_in
	mov a,#SPEAKER_OFF
	acall data_in
	ret
command:
    acall busy				;Sending command to LCD
	MOV P2,A
	CLR rs
	CLR rw
	SETB en
	CLR en
	RET
data_in:
    acall busy				;Sending data to LCD
	SETB rs
	MOV P2,A
	CLR rw
	SETB en
	CLR en
	RET
busy:
	;SETB P2.7				;Checking Busy flag
	mov P2, #0FFH
	CLR rs
	SETB rw
wait:
	CLR en
	SETB en
	JB P2.7,wait
	RET
day:
	push acc				;Displaying day subroutine for RTC
	cjne a,#01,skip
	disp_str < Minggu>
	ljmp exit
skip:	cjne a,#02,skip2
	disp_str < Senin>
	ljmp exit
skip2:
	cjne a,#03,skip3
	disp_str < Selasa>
	ljmp exit
skip3:
	cjne a,#04,skip4
	disp_str < Rabu>
	ajmp exit
skip4:
	cjne a,#05,skip5
	disp_str< Kamis>
	sjmp exit
skip5:
    cjne a,#06,skip6
	disp_str < Jumat>
	sjmp exit
skip6:	disp_str < Sabtu>
exit:
	pop acc
	ret
time_set:					;Setting time subroutine
	jnb time_key,$
	mov a,#1
	acall command
	mov a,#80h
	acall command
	mov a,#CLOCK
	acall data_in
	disp_str < set menit >
	mov a,#0c5h
	acall command
	mov a,51h
	acall disp_val
	lcall hexdec
key:
	push acc
	mov a,#0c5h
	acall command
	pop acc
	jb increment,chk1
	inc a
	cjne a,#60,ok1
	mov a,#0
ok1:
	jnb increment,$
	lcall dechex
	acall disp_val
	lcall hexdec
	sjmp key
chk1:	jb decrement,chk2
	dec a
	cjne a,#0ffh,ok2
	mov a,#59
ok2:
	jnb decrement,$
	lcall dechex
	acall disp_val
	lcall hexdec
	sjmp key
chk2:
	jb time_key,key
	lcall dechex
	mov min,a
	jnb time_key,$
	mov a,#1
	acall command
	mov a,#80h
	acall command
	mov a,#CLOCK
	acall data_in
	disp_str < set jam >
	mov a,#0c5h
	acall command
	mov a,52h
	anl a,#1fh
	acall disp_val
	lcall hexdec
key1:
	push acc
	mov a,#0c5h
	acall command
	pop acc
	jb increment,chk3
	inc a
	cjne a,#13,ok3
	mov a,#1
ok3:
	jnb increment,$
	lcall dechex
	acall disp_val
	lcall hexdec
	sjmp key1
chk3:
	jb decrement,chk4
	dec a
	cjne a,#0,ok4
	mov a,#12
ok4:	jnb decrement,$
	lcall dechex
	acall disp_val
	lcall hexdec
	sjmp key1
chk4:
	jb time_key,key1
	lcall dechex
	mov hour,a
	jnb time_key,$
	mov a,#1
	acall command
	mov a,#80h
	acall command
	mov a,#CLOCK
	acall data_in
	disp_str < set am/pm:>
	mov a,52h
	anl a,#20h
	cjne a,#00h,pm1
	mov a,#0c5h
	acall command
	disp_str <am>
	setb ampm_flag
	sjmp key2
pm1:
	mov a,#0c5h
	acall command
	disp_str <pm>
	clr ampm_flag
key2:
	mov a,#0c5h
	acall command
	jb increment,chk5
	jb ampm_flag,ok5
	setb ampm_flag
	disp_str <am>
	hold
	jnb increment,$
	sjmp key2
ok5:
	clr ampm_flag
	disp_str <pm>
	hold
	jnb increment,$
	sjmp key2
chk5:
	jb decrement,chk6
	jb ampm_flag,ok6
	setb ampm_flag
	disp_str <am>
	hold
	jnb decrement,$
	sjmp key2
ok6:
	clr ampm_flag
	disp_str <pm>
	hold
	jnb decrement,$
	sjmp key2
chk6:
	jb time_key,key2
	jnb ampm_flag,noam
	mov a,hour
	add a,#40h
	sjmp nopm
noam:
	mov a,hour
	add a,#60h
nopm:
	mov hour,a
	jnb time_key,$
	mov a,#1
	lcall command
	mov a,#80h
	lcall command
	mov a,#CLOCK
	lcall data_in
	disp_str < set hari >
	mov a,#0c5h
	lcall command
	mov a,53h
	push acc
	lcall day
	pop acc
key3:
	push acc
	mov a,#0c5h
	lcall command
	pop acc
	jb increment,chk7
	inc a
	cjne a,#8,ok7
	mov a,#1
ok7:
	jnb increment,$
	push acc
	lcall day
	pop acc
	sjmp key3
chk7:
	jb decrement,chk8
	dec a
	cjne a,#0,ok8
	mov a,#7
ok8:
	jnb decrement,$
	push acc
	lcall day
	pop acc
	sjmp key3
chk8:
	jb time_key,key3
	mov days,a
	jnb time_key,$
	mov a,#1
	lcall command
	mov a,#80h
	lcall command
	mov a,#CLOCK
	lcall data_in
	disp_str < set tanggal >
	mov a,#0c5h
	lcall command
	mov a,54h
	lcall disp_val
	lcall hexdec
key4:
	push acc
	mov a,#0c5h
	lcall command
	pop acc
	jb increment,chk9
	inc a
	cjne a,#32,ok9
	mov a,#1
ok9:
	jnb increment,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp key4
chk9:
	jb decrement,chk10
	dec a
	cjne a,#0,ok10
	mov a,#31
ok10:
	jnb decrement,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp key4
chk10:
	jb time_key,key4
	lcall dechex
	mov date,a
	jnb time_key,$
	mov a,#1
	lcall command
	mov a,#80h
	lcall command
	mov a,#CLOCK
	lcall data_in
	disp_str < set bulan >
	mov a,#0c5h
	lcall command
	mov a,55h
	lcall disp_val
	lcall hexdec
key5:
	push acc
	mov a,#0c5h
	lcall command
	pop acc
	jb increment,chk11
	inc a
	cjne a,#13,ok11
	mov a,#1
ok11:
	jnb increment,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp key5
chk11:
	jb decrement,chk12
	dec a
	cjne a,#0,ok12
	mov a,#12
ok12:
	jnb decrement,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp key5
chk12:
	jb time_key,key5
	lcall dechex
	mov month,a
	jnb time_key,$
	mov a,#1
	lcall command
	mov a,#80h
	lcall command
	mov a,#CLOCK
	lcall data_in
	disp_str < set tahun >
	mov a,#0c5h
	lcall command
	mov a,56h
	lcall disp_val
	lcall hexdec
key6:
	push acc
	mov a,#0c5h
	lcall command
	pop acc
	jb increment,chk13
	inc a
	cjne a,#100,ok13
	mov a,#0
ok13:
	jnb increment,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp key6
chk13:
	jb decrement,chk14
	dec a
	cjne a,#0ffh,ok14
	mov a,#99
ok14:
	jnb decrement,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp key6
chk14:
	jb time_key,key6
	jnb time_key,$
	lcall dechex
	mov year,a
	mov alarm,#00
	mov sig,#'~'
	clr time_flag
	ret
alarm_set:					;Setting Alarm Subroutine
	jnb alarm_key,$
	mov a,#1
	lcall command
	mov a,#80h
	lcall command
	mov a,#BELL
	lcall data_in
	mov a,#0c5h
	lcall command
	mov a,#0h	;default menit alarm	 (  00	 )
	lcall disp_val
	lcall hexdec
akey:
	push acc
	mov a,#0c5h
	lcall command
	pop acc
	jb increment,achk1		  ;ngurangan menit
	inc a
	cjne a,#60,aok1
	mov a,#0
aok1:
	jnb increment,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp akey
achk1:
	jb decrement,achk2
	dec a
	cjne a,#0ffh,aok2
	mov a,#59
aok2:
    jnb decrement,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp akey
achk2:
    jb alarm_key,akey
	lcall dechex
	mov alarm_min,a
	jnb alarm_key,$
	mov a,#1
	lcall command
	mov a,#80h
	lcall command
	mov a,#BELL
	lcall data_in
	mov a,#0c5h
	lcall command
	mov a,#45h		;default jam alarm (05)
	anl a,#1fh
	lcall disp_val
	lcall hexdec
akey1:
	push acc
	mov a,#0c5h
	lcall command
	pop acc
	jb increment,achk3
	inc a
	cjne a,#13,aok3
	mov a,#1
aok3:
	jnb increment,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp akey1
achk3:
	jb decrement,achk4
	dec a
	cjne a,#0,aok4
	mov a,#12
aok4:
	jnb decrement,$
	lcall dechex
	lcall disp_val
	lcall hexdec
	sjmp akey1
achk4:
	jb alarm_key,akey1
	lcall dechex
	mov alarm_hrs,a
	jnb alarm_key,$
	mov a,#1
	lcall command
	mov a,#80h
	lcall command
	mov a,#BELL
	lcall data_in
	mov a,#0c5h
	lcall command
	mov a,alarm_hrs
	anl a,#20h
	cjne a,#20h,its_pm
	disp_str <am>
	setb ampm_flag
	sjmp akey2
its_pm:
	disp_str <pm>
	clr ampm_flag
akey2:
	mov a,#0c5h
	lcall command
	jb increment,achk5
	jb ampm_flag,aok5
	setb ampm_flag
	disp_str <am>
	hold
	jnb increment,$
	sjmp akey2
aok5:
	clr ampm_flag
	disp_str <pm>
	hold
	jnb increment,$
	sjmp akey2
achk5:
	jb decrement,achk6
	jb ampm_flag,aok6
	setb ampm_flag
	disp_str <am>
	hold
	jnb decrement,$
	sjmp akey2
aok6:
	clr ampm_flag
	disp_str <pm>
	hold
	jnb decrement,$
	sjmp akey2
achk6:
	jb alarm_key,akey2
	jnb alarm_key,$
	mov a,alarm_hrs
	jb ampm_flag,anoam
	add a,#60h
	sjmp anopm
anoam:
	mov a,alarm_hrs
	add a,#40h
anopm:
	mov alarm_hrs,a
	mov ahour,alarm_hrs
	mov amin,alarm_min
	mov r6,#02h
	mov r0,#39h
	mov r1,#09h
	lcall rtc_ini
	mov a,#1h
	lcall command
	mov a,#81h
	lcall command
	mov a,#OK
	lcall data_in
	disp_str < T M On!>
	mov a,#0c4h
	lcall command
	mov a,alarm_hrs
	anl a,#1fh
	lcall disp_val
	mov a,#':'
	lcall data_in
	mov a,alarm_min
	lcall disp_val
	mov a,alarm_hrs
	anl a,#20h
	cjne a,#00h,ppm
	disp_str < am>
	sjmp ppass2
ppm:
	disp_str < pm>
ppass2:
	mov r7,#35
	setb tr0
looop:
	jnb tf0,$
	clr tf0
	djnz r7,looop
	clr tr0
	mov a,#1h
	lcall command
	lcall disp_const
	mov a,#SPEAKER_ON
	lcall data_in
	setb alarm_off
	setb alarm_on
	clr alarm_flag
	clr alarm_flag
	ret
dechex:
	mov b,#0ah				;Decimal to Hexadecimal conversion
	div ab
	mov 60h,b
	mov b,#10h
	mul ab
	add a,60h
	ret
hexdec:
	mov b,#10h				;Hexadecimal to deciaml conversion
	div ab
	mov 60h,b
	mov b,#0ah
	mul ab
	add a,60h
	ret
ascii:						;ASCII lookup table
db	30h,31h,32h,33h,34h,35h,36h,37h,38h,39h
	end
pleas help me....
according to the above souce code
where I can read what time it is the first time while the clock is turned?
thx
ask yourself .. answered his own .. it's all right .. just sharing;-)
I have found the solution
.... by simulated in proteus and Show Logic State of Pins is enabled ..
first, the source code in the edit, the data hours, minutes and seconds spent through P0 unused, then run the simulation proteus and see the display logic in the P0 data ... this is the data generated to determine the hours, minutes and seconds that are running
Data hour : 41h - 52h = 1am-12am
59h - 72h = 1pm - 12 pm
Data minute : 00h-60h
Data seconds : 00h - 60h
example : at 03 : 20 : 15 am = 43h : 20h : 15h
at 05 : 30 : 10 pm = 65h : 30h : 10h
I plan to make a digital clock with multi-function 2 display LCD and 6 pcs 7 segment ....
problem encountered is, whether the data that I got earlier data can be used to turn on 7 segment
I am happy, if your friends all want to share it with sincerity:-o
thx
