Li_ereunpisan
Full Member level 5
- Joined
- Jul 14, 2009
- Messages
- 260
- Helped
- 32
- Reputation
- 64
- Reaction score
- 28
- Trophy points
- 1,308
- Location
- Bandung, Indonesia
- Activity points
- 2,768
use a timer interrupt(set it at 5) for 12hrs..
it will simply flip the previous state..if it was on at 5am then it will gt switched off at 5pm..and so on..
or
u may use real time clock and then then check the data and make the further program ....
I agree with beyondH.
In your case wanditea, your schematics it is simply. If you want to keep simply, use digital clock (timer interrupt). You must write some code lines and defined digital clock, because timer which you have in microcontroller could not count hours, but you do not need change the board.
Of course, you must set up digital clock, but you have tasters and LCD on board already, and you can use that elements for set up of digital clock.
how to set your alarm be applied to the relay ... example: at the time at 05.00 am at the relay ON and relay OFF at 05.00 pm
I think that some bright LED 7-segment display would be better because it is more easily readable. LCD is very angle dependant. Plus with 7-segment displays you can get digits much, much bigger than with lcd.
hold macro
nop
nop
nop
nop
endm
disp_str macro string ;Macro for sending string to LCD
irpc char, <string>
if nul 'char'
exitm
endif
mov a,#'char'
lcall data_in
endm
endm
build_char macro P1,P2,P3,P4,P5,P6,P7,P8 ;Macro for building a custom character
irp arg, <P1,P2,P3,P4,P5,P6,P7,P8>
mov a,#arg
acall data_in
endm
endm
sec equ 30h ;second register
min equ 31h ;minutes register
hour equ 32h ;hour register
days equ 33h ;days register
date equ 34h ;date register
month equ 35h ;month register
year equ 36h ;year register
alarm equ 37h ;alarm register
sig equ 38h ;signature for data checking in RTC RAM
ahour equ 39h ;alarm hour register
amin equ 3Ah ;alarm minute register
sda equ P1.1 ;Serial data pin
scl equ P1.0 ;Serial clock pin
rw equ p3.6 ;read write pin of LCD
en equ p3.5 ;enable pin of LCD
rs equ p3.7 ;register select pin of LCD
alarm_key equ p3.3 ;Alarm set key
time_key equ p3.2 ;Time ser key
increment equ p1.3 ;Increment value
decrement equ p1.2 ;Decrement Value
[COLOR="#FF0000"]relay equ p1.4 ;plisss edit to daily alarm[/COLOR]
alarm_flag equ 20h ;flag for alarm
time_flag equ 21h ;flag for time
ampm_flag equ 22h ;am/pm flag
alarm_on equ 23h ;Alarm on flag
alarm_off equ 24h ;alarm off flag
alarm_ring equ 25h ;alarm ring flag
alarm_hrs equ 58h ;Alarm hour register
alarm_min equ 59h ;Alarm Minutes register
alarm_chk_hour equ 5Ah ;Alarm hour check register
alarm_chk_min equ 5Bh ;Alarm min check register
ampm equ 61h ;AM/PM register
BELL equ 7h ;Bell icon
SPEAKER_OFF equ 1h ;speaker off icon
SPEAKER_ON equ 2h ;speaker on icon
CLOCK equ 3h ;clock icon
OK equ 4h ;ok icon
HEART equ 5h ;heart icon
MUSIC equ 6h ;music icon
org 0000h ;Starting of main program
ljmp start
org 03h ;interrupt for set time
setb time_flag
reti
org 13h ;Interrupt for set alarm
setb alarm_flag ;and switch off the alarm if on
jb alarm_off,trs
ajmp hmmm
trs:
setb alarm_port
setb relay
mov a,#1h
lcall command ;parentah lcd
mov a,#81h
lcall command
mov a,#OK
acall data_in ;kirim data lcd
mov r7,#35
disp_str < T M Off!>
setb tr0
loooop:
jnb tf0,$
clr tf0
djnz r7,loooop
clr tr0
mov a,#1h
acall command
acall disp_const
setb alarm_off
setb alarm_on
clr alarm_flag
clr alarm_flag
clr alarm_on
setb alarm_port
setb relay
clr alarm_off
clr alarm_flag
clr alarm_ring
hmmm: reti
start:
;clear RAM
mov R0,#7FH
clr A
clr_ram:
mov @R0,A
djnz R0, clr_ram
;Init I2C Port
lcall i2cinit
mov tmod,#1h ;start routine
mov sp,#10h
acall initial
acall build
mov a,#80h
acall command
mov a,#CLOCK
acall data_in
disp_str < T M Create by RnD > ;Name display
mov r7,#50
;disp_str < Create by RnD > ;Name display
;mov r7,#50
setb tr0
wloop:
jnb tf0,$
clr tf0
djnz r7,wloop
clr time_flag
clr alarm_flag
clr alarm_on
clr ampm_flag
setb alarm_port
setb relay
lcall startc ;Reading invalid hour entry
mov a,#0d0h ;initialize the RTC if necessary
lcall send
lcall ack
mov a,#02h
lcall send
lcall ack
lcall rstart
mov a,#0d1h
acall send
acall ack
acall read
acall nak
acall stop
anl a,#1fh
cjne a,#12h,step
step:
jnc done
acall startc ;Reading signature byte if same then no need
mov a,#0d0h ;of initialization else initialize the RTC
acall send
acall ack
mov a,#08h
acall send
acall ack
acall rstart
mov a,#0d1h
acall send
acall ack
acall read
acall nak
acall stop
cjne a,#'~',done
sjmp run
done:
;acall initial
;acall disp_const
mov sec,#00h ;For more information about the RTC DS1307
mov min,#0h ;Please refer to the datasheet
mov hour,#52h ;21h for 24 hour format
mov days,#01h
mov date,#1h
mov month,#1h
mov year,#06h
mov alarm,#0
mov sig,#'~'
mov ahour,#0
mov amin,#0
mov r6,#0bh
mov r0,#sec
mov r1,#00h
acall rtc_ini ;initializing RTC if required
run:
mov ie,#85h
acall initial
acall disp_const
run1:
acall startc ;Actual Starting
mov a,#0d0h
acall send
acall ack
mov a,#00h
acall send
acall ack
mov r6,#0fh
acall rstart ;Reading the RCT content
mov a,#0d1h
acall send
acall ack
mov r0,#40h
here:
lcall read
mov @r0,a
inc r0
cjne r6,#1,sendack
acall nak
sjmp naksent
sendack:
acall ack
naksent:
djnz r6,here
acall stop
acall display ;Display RTC
jnb time_flag,noset ;check for time flag if set the set the clock
clr time_flag
clr ea
acall time_set
clr time_flag
mov r6,#09h
mov r0,#30h
mov r1,#00h
acall rtc_ini
clr time_flag
mov a,#1h
acall command
mov a,#81h
acall command
mov a,#OK
acall data_in
clr time_flag
disp_str < set waktu >
mov r7,#35
setb tr0
looooop:
jnb tf0,$
clr tf0
djnz r7,looooop
clr tr0
mov a,#1h
acall command
acall disp_const
setb ea
noset:
jnb alarm_flag,noset1 ;check for alarm flag if set then set alarm
clr alarm_flag
clr ea
lcall alarm_set
setb ea
setb alarm_on
clr alarm_flag
setb alarm_on
noset1:
jnb alarm_ring,noset2 ;check if alarm ring flag is set
[COLOR="#FF0000"]clr relay ;plis edit to daily alarm[/COLOR]
noset2: ljmp run1 ;Do everything again
;Initializing I2C Bus Communication
i2cinit:
setb sda
setb scl
ret
;ReStart Condition for I2C Communication
rstart:
clr scl
setb sda
setb scl
clr sda
ret
;Start Condition for I2C Communication
startc:
setb scl
clr sda
clr scl
ret
;Stop Condition For I2C Bus
stop:
clr scl
clr sda
setb scl
setb sda
ret
;Sending Data to slave on I2C bus
send:
mov r7,#08
back:
clr scl
rlc a
mov sda,c
setb scl
djnz r7,back
clr scl
setb sda
ret
;ACK and NAK for I2C Bus
ack:
clr sda
setb scl
clr scl
setb sda
ret
nak:
setb sda
setb scl
clr scl
setb scl
ret
;Receiving Data from slave on I2C bus
read:
mov r7,#08
back2:
clr scl
setb scl
mov c,sda
rlc a
djnz r7,back2
clr scl
setb sda
ret
recv: ;Recieving data from I2C bus
lcall read
lcall ack
mov @r0,a
inc r0
ret
rtc_ini:
acall startc ;RTC initialization subroutine
mov a,#0d0h
acall send
acall ack
mov a,r1
acall send
acall ack
rtc_ini_loop:
mov a,@r0
acall send
acall ack
inc r0
inc r1
;acall stop
djnz r6,rtc_ini_loop
acall stop
ret
initial:
mov a,#38h ;LCD initialization subroutine
acall command
mov a,#0ch
acall command
mov a,#01h
acall command
mov a,#06h
acall command
ret
build:
mov a,#40h ;Building custom character routine
acall command
build_char 0h,0h,0h,0h,0h,0h,0h,0h ;BELL
build_char 17h,4h,14h,17h,14h,14h,14h,0h ;relay off 1h,3h,0fh,0fh,0fh,3h,1h,0h ;SPEAKER OFF
build_char 13h,15h,19h,0h,1fh,1h,2h,0h ;relay on 8h,10h,0h,18h,0h,10h,8h,0h ;SPEAKER ON
build_char 0h,0eh,15h,17h,11h,0eh,0h,0h ;CLOCK
build_char 0h,1h,3h,16h,1ch,8h,0h,0h ;OK
build_char 0ah,1fh,1fh,1fh,0eh,4h,0h,0h ;HEART
build_char 2h,3h,2h,0eh,1eh,0ch,0h,0h ;MUSIC
build_char 0eh,11h,1fh,0h,1fh,2h,1fh,0h ; aink 4h,0eh,0eh,0eh,1fh,0h,4h,0h ;BELL
ret
display:
mov r1,#40h ;Displaying RTC content
mov a,#0Cah
acall command
mov a,@r1
mov 50h,@r1
acall disp_val
PASS:
inc r1
mov a,#0C7h
acall command
mov a,@r1
mov 51h,@r1
mov alarm_chk_min,@r1
acall disp_val
PASS1:
inc r1
mov a,#0c4h
acall command
mov a,@r1
mov 52h,@r1
mov alarm_chk_hour,@r1
mov r4,a
anl a,#1fh
acall disp_val
mov a,r4
anl a,#20h
cjne a,#00h,pm
mov a,#0cdh
acall command
disp_str <am>
sjmp pass2
pm: mov a,#0cdh
acall command
disp_str <pm>
PASS2: inc r1
mov a,#80h
acall command
mov a,@r1
mov 53h,@r1
acall day
PASS3:
inc r1
mov a,#88h
acall command
mov a,@r1
mov 54h,@r1
acall disp_val
PASS4:
inc r1
mov a,#8bh
acall command
mov a,@r1
mov 55h,@r1
acall disp_val
PASS5:
inc r1
mov a,#8eh
acall command
mov a,@r1
mov 56h,@r1
acall disp_val
jnb alarm_on,PASS6
inc r1
inc r1
inc r1
mov a,@r1
cjne a,52h,PASS6
inc r1
mov a,@r1
cjne a,51h,PASS6
setb alarm_ring
setb alarm_ring
PASS6: ret
disp_val: ;Display 8-bit Decimal Value
push acc
mov r5,a
anl a,#0f0h
swap a
mov dptr,#ascii
movc a,@a+dptr
acall data_in
mov a,r5
anl a,#0fh
movc a,@a+dptr
acall data_in
pop acc
ret
disp_const: ;Display constant characters
mov a,#8ah
acall command
mov a,#'/'
acall data_in
mov a,#8dh
acall command
mov a,#'/'
acall data_in
mov a,#0c6h
acall command
mov a,#':'
acall data_in
mov a,#0c9h
acall command
mov a,#':'
acall data_in
mov a,#0c0h
acall command
mov a,#BELL
acall data_in
mov a,#SPEAKER_OFF
acall data_in
ret
command:
acall busy ;Sending command to LCD
MOV P2,A
CLR rs
CLR rw
SETB en
CLR en
RET
data_in:
acall busy ;Sending data to LCD
SETB rs
MOV P2,A
CLR rw
SETB en
CLR en
RET
busy:
;SETB P2.7 ;Checking Busy flag
mov P2, #0FFH
CLR rs
SETB rw
wait:
CLR en
SETB en
JB P2.7,wait
RET
day:
push acc ;Displaying day subroutine for RTC
cjne a,#01,skip
disp_str < Minggu>
ljmp exit
skip: cjne a,#02,skip2
disp_str < Senin>
ljmp exit
skip2:
cjne a,#03,skip3
disp_str < Selasa>
ljmp exit
skip3:
cjne a,#04,skip4
disp_str < Rabu>
ajmp exit
skip4:
cjne a,#05,skip5
disp_str< Kamis>
sjmp exit
skip5:
cjne a,#06,skip6
disp_str < Jumat>
sjmp exit
skip6: disp_str < Sabtu>
exit:
pop acc
ret
time_set: ;Setting time subroutine
jnb time_key,$
mov a,#1
acall command
mov a,#80h
acall command
mov a,#CLOCK
acall data_in
disp_str < set menit >
mov a,#0c5h
acall command
mov a,51h
acall disp_val
lcall hexdec
key:
push acc
mov a,#0c5h
acall command
pop acc
jb increment,chk1
inc a
cjne a,#60,ok1
mov a,#0
ok1:
jnb increment,$
lcall dechex
acall disp_val
lcall hexdec
sjmp key
chk1: jb decrement,chk2
dec a
cjne a,#0ffh,ok2
mov a,#59
ok2:
jnb decrement,$
lcall dechex
acall disp_val
lcall hexdec
sjmp key
chk2:
jb time_key,key
lcall dechex
mov min,a
jnb time_key,$
mov a,#1
acall command
mov a,#80h
acall command
mov a,#CLOCK
acall data_in
disp_str < set jam >
mov a,#0c5h
acall command
mov a,52h
anl a,#1fh
acall disp_val
lcall hexdec
key1:
push acc
mov a,#0c5h
acall command
pop acc
jb increment,chk3
inc a
cjne a,#13,ok3
mov a,#1
ok3:
jnb increment,$
lcall dechex
acall disp_val
lcall hexdec
sjmp key1
chk3:
jb decrement,chk4
dec a
cjne a,#0,ok4
mov a,#12
ok4: jnb decrement,$
lcall dechex
acall disp_val
lcall hexdec
sjmp key1
chk4:
jb time_key,key1
lcall dechex
mov hour,a
jnb time_key,$
mov a,#1
acall command
mov a,#80h
acall command
mov a,#CLOCK
acall data_in
disp_str < set am/pm:>
mov a,52h
anl a,#20h
cjne a,#00h,pm1
mov a,#0c5h
acall command
disp_str <am>
setb ampm_flag
sjmp key2
pm1:
mov a,#0c5h
acall command
disp_str <pm>
clr ampm_flag
key2:
mov a,#0c5h
acall command
jb increment,chk5
jb ampm_flag,ok5
setb ampm_flag
disp_str <am>
hold
jnb increment,$
sjmp key2
ok5:
clr ampm_flag
disp_str <pm>
hold
jnb increment,$
sjmp key2
chk5:
jb decrement,chk6
jb ampm_flag,ok6
setb ampm_flag
disp_str <am>
hold
jnb decrement,$
sjmp key2
ok6:
clr ampm_flag
disp_str <pm>
hold
jnb decrement,$
sjmp key2
chk6:
jb time_key,key2
jnb ampm_flag,noam
mov a,hour
add a,#40h
sjmp nopm
noam:
mov a,hour
add a,#60h
nopm:
mov hour,a
jnb time_key,$
mov a,#1
lcall command
mov a,#80h
lcall command
mov a,#CLOCK
lcall data_in
disp_str < set hari >
mov a,#0c5h
lcall command
mov a,53h
push acc
lcall day
pop acc
key3:
push acc
mov a,#0c5h
lcall command
pop acc
jb increment,chk7
inc a
cjne a,#8,ok7
mov a,#1
ok7:
jnb increment,$
push acc
lcall day
pop acc
sjmp key3
chk7:
jb decrement,chk8
dec a
cjne a,#0,ok8
mov a,#7
ok8:
jnb decrement,$
push acc
lcall day
pop acc
sjmp key3
chk8:
jb time_key,key3
mov days,a
jnb time_key,$
mov a,#1
lcall command
mov a,#80h
lcall command
mov a,#CLOCK
lcall data_in
disp_str < set tanggal >
mov a,#0c5h
lcall command
mov a,54h
lcall disp_val
lcall hexdec
key4:
push acc
mov a,#0c5h
lcall command
pop acc
jb increment,chk9
inc a
cjne a,#32,ok9
mov a,#1
ok9:
jnb increment,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp key4
chk9:
jb decrement,chk10
dec a
cjne a,#0,ok10
mov a,#31
ok10:
jnb decrement,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp key4
chk10:
jb time_key,key4
lcall dechex
mov date,a
jnb time_key,$
mov a,#1
lcall command
mov a,#80h
lcall command
mov a,#CLOCK
lcall data_in
disp_str < set bulan >
mov a,#0c5h
lcall command
mov a,55h
lcall disp_val
lcall hexdec
key5:
push acc
mov a,#0c5h
lcall command
pop acc
jb increment,chk11
inc a
cjne a,#13,ok11
mov a,#1
ok11:
jnb increment,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp key5
chk11:
jb decrement,chk12
dec a
cjne a,#0,ok12
mov a,#12
ok12:
jnb decrement,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp key5
chk12:
jb time_key,key5
lcall dechex
mov month,a
jnb time_key,$
mov a,#1
lcall command
mov a,#80h
lcall command
mov a,#CLOCK
lcall data_in
disp_str < set tahun >
mov a,#0c5h
lcall command
mov a,56h
lcall disp_val
lcall hexdec
key6:
push acc
mov a,#0c5h
lcall command
pop acc
jb increment,chk13
inc a
cjne a,#100,ok13
mov a,#0
ok13:
jnb increment,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp key6
chk13:
jb decrement,chk14
dec a
cjne a,#0ffh,ok14
mov a,#99
ok14:
jnb decrement,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp key6
chk14:
jb time_key,key6
jnb time_key,$
lcall dechex
mov year,a
mov alarm,#00
mov sig,#'~'
clr time_flag
ret
alarm_set: ;Setting Alarm Subroutine
jnb alarm_key,$
mov a,#1
lcall command
mov a,#80h
lcall command
mov a,#BELL
lcall data_in
mov a,#0c5h
lcall command
mov a,#0h ;default menit alarm ( 00 )
lcall disp_val
lcall hexdec
akey:
push acc
mov a,#0c5h
lcall command
pop acc
jb increment,achk1 ;ngurangan menit
inc a
cjne a,#60,aok1
mov a,#0
aok1:
jnb increment,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp akey
achk1:
jb decrement,achk2
dec a
cjne a,#0ffh,aok2
mov a,#59
aok2:
jnb decrement,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp akey
achk2:
jb alarm_key,akey
lcall dechex
mov alarm_min,a
jnb alarm_key,$
mov a,#1
lcall command
mov a,#80h
lcall command
mov a,#BELL
lcall data_in
mov a,#0c5h
lcall command
mov a,#45h ;default jam alarm (05)
anl a,#1fh
lcall disp_val
lcall hexdec
akey1:
push acc
mov a,#0c5h
lcall command
pop acc
jb increment,achk3
inc a
cjne a,#13,aok3
mov a,#1
aok3:
jnb increment,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp akey1
achk3:
jb decrement,achk4
dec a
cjne a,#0,aok4
mov a,#12
aok4:
jnb decrement,$
lcall dechex
lcall disp_val
lcall hexdec
sjmp akey1
achk4:
jb alarm_key,akey1
lcall dechex
mov alarm_hrs,a
jnb alarm_key,$
mov a,#1
lcall command
mov a,#80h
lcall command
mov a,#BELL
lcall data_in
mov a,#0c5h
lcall command
mov a,alarm_hrs
anl a,#20h
cjne a,#20h,its_pm
disp_str <am>
setb ampm_flag
sjmp akey2
its_pm:
disp_str <pm>
clr ampm_flag
akey2:
mov a,#0c5h
lcall command
jb increment,achk5
jb ampm_flag,aok5
setb ampm_flag
disp_str <am>
hold
jnb increment,$
sjmp akey2
aok5:
clr ampm_flag
disp_str <pm>
hold
jnb increment,$
sjmp akey2
achk5:
jb decrement,achk6
jb ampm_flag,aok6
setb ampm_flag
disp_str <am>
hold
jnb decrement,$
sjmp akey2
aok6:
clr ampm_flag
disp_str <pm>
hold
jnb decrement,$
sjmp akey2
achk6:
jb alarm_key,akey2
jnb alarm_key,$
mov a,alarm_hrs
jb ampm_flag,anoam
add a,#60h
sjmp anopm
anoam:
mov a,alarm_hrs
add a,#40h
anopm:
mov alarm_hrs,a
mov ahour,alarm_hrs
mov amin,alarm_min
mov r6,#02h
mov r0,#39h
mov r1,#09h
lcall rtc_ini
mov a,#1h
lcall command
mov a,#81h
lcall command
mov a,#OK
lcall data_in
disp_str < T M On!>
mov a,#0c4h
lcall command
mov a,alarm_hrs
anl a,#1fh
lcall disp_val
mov a,#':'
lcall data_in
mov a,alarm_min
lcall disp_val
mov a,alarm_hrs
anl a,#20h
cjne a,#00h,ppm
disp_str < am>
sjmp ppass2
ppm:
disp_str < pm>
ppass2:
mov r7,#35
setb tr0
looop:
jnb tf0,$
clr tf0
djnz r7,looop
clr tr0
mov a,#1h
lcall command
lcall disp_const
mov a,#SPEAKER_ON
lcall data_in
setb alarm_off
setb alarm_on
clr alarm_flag
clr alarm_flag
ret
dechex:
mov b,#0ah ;Decimal to Hexadecimal conversion
div ab
mov 60h,b
mov b,#10h
mul ab
add a,60h
ret
hexdec:
mov b,#10h ;Hexadecimal to deciaml conversion
div ab
mov 60h,b
mov b,#0ah
mul ab
add a,60h
ret
ascii: ;ASCII lookup table
db 30h,31h,32h,33h,34h,35h,36h,37h,38h,39h
end
