[ASK] Converter DC 9 V to 5 V
afnindar
Junior Member level 1
ask converter
anybody can help me to convert 9 V DC to 5V ?
convert 9v to 3.3v
Take a look at the 7805 vltage regulator ..
It is the easiest way of converting +9V to +5V ..
Rgards,
IanP
i will ask with ">8V", How Much Maximum Voltage allowed?
Maximum input voltage for 7805 voltage regulators is 35V ..
Regards,
IanP
i have read the datasheet about LM7805, i curious about the thermal ? cant they blow out cause the thermal ?
The 7805, and in general all 78XX voltage regulators, has all sorts of internal protections, including Internal Short-Circuit Current Limiting, Output Transistor Safe-Area Compensation, .. , Internal Thermal-Overload Protection ..
If they are not exposed to higher voltages they are rated for, they will not fail ..
Regards,
IanP
0 Volt is sinyal ground? right?
how about converter from > 9 V DC to 3.0 or 3.3 V DC?
0V = GND = Ground ..
To step-down from 9V to 3 or 3.3V you can use fixed voltage regulators (go google), or you can use the very popular adjustable voltage regulator: LM317 .. see picture below ..
Regards,
IanP
R1 and R2 in Ohm or Kilo Ohm or Mega Ohm?
In this case the values are in Ohms (Ω) ..
Regards,
IanP
do you know how to calc within LM317 Output Power, Resistor 1 and Resistor 2?
Added after 13 minutes:
i guess :
that the calculate every R2 + 240 regulated up to 3 volt? right?
Added after 6 minutes:
so if i want to output power is 3.3 V so i must change R2 to be value :
assume 1 Volt = 80 Ohm
so 0,1 V = 8 Ohm
3.0 V = 140
3.3 V = 140 + (8*3)
3.3 V = 164 Ohm
CMIIW
Take a look at the picture below ..
- 1.25V in this formula represents internal voltage reference ..
- 240Ω is the recommended value for R1 ..
- R2*Iadj is very small and can be removed from the equation ..
Taking into account all of the above, for 3.3V output voltage the value of R2 should be ≈394Ω (the closest choice 390Ω) ..
Regards,
IanP
on that case you show to me. the electricity go through the LM317 and not to save to the capacitor first, your first picture LM317 which are there 2 capacitor polarized and non polarized, so electricity could save to them. which save can i used for my regulator?
if i used your first picture your calculation based on datasheet is not match ?
CMIIW
Added after 27 minutes:
i want to ask about the value of C1? are same with value of C2?
regards
C1 can be also 10µF but I would add 100nF ceramic capacitor right next to it ..
As far as the input side is concerned, you can use 100-1000µF electrolytic capacitor and, again, 100nF ceramic ..
The formula from the LM317's data sheet is correct and in both given examples I can't see any incorrect values ..
Regards,
IanP
    afnindar
thanks for attention,
great explanation...
regards
