ascii conversion code samples
userx51
Junior Member level 2
hi,
I am very new to C and inside MCU, I need to convert from bin2ascii and ascii2bin in order to read and write to hyperterminal?. any sample codes in C?.:?:
I am sorry, how do i convert 2F to ascii. and how to convert it back to bin in C language. sorry for my lack of familiarity. just started reading about it. within the MCU. I work with hyper terminal. experimenting motor motion.
as give example if u want to send 2F then senf lsb nibble by using masking of 0x0f and again shift msb nibble to lsb side again do same.
example:
unsigned char ascii_array[16]={"0123456789ABCDEF"};
void send_ascii(unsigned char dat)
unsigned char temp;
temp = dat & 0x0F;
tx(ascii_array[temp]);
temp = dat >> 4;
temp = temp & 0x0f;
and if u want to convert it to in bin form then
if(num <9 && num >0)
num = num-'0';
if num is A to F then minus 'A'
and then again combine it in reverse manner
If you just want single character/digit conversions, these should work:
char AscToBin(char AsciiChar)
	if(AsciiChar > '9') AsciiChar -= 7;
	return((AsciiChar - '0') & 0x0F);
char BinToAsc(char BinValue)
	BinValue &= 0x0F;
	if(BinValue > 9) BinValue += 7;
	return(BinValue + '0');
Call the appropriate one with the character/digit as the parameter and it will return the converted version, for example:
AsciiCharacter = BinToAsc(5); Will return the Ascii character '5' (0x35)
BinaryValue = AscToBin('A'); will return 0x0A
Brian.
