Array type case expression must be locally static subtype
dohzer
Member level 1
Member level 1
array type case expression
I'm getting the following error when compiling in ModelSim:
Array type case expression must be of a locally static subtype.
The error points to the first part of the case statement in the following code:
library ieee;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity amplitude_lookup is
	generic
		TRUNC_PHASE_WIDTH 		: integer := 16;
		QUADRANT_WIDTH			: integer := 2;
		ADDR_WIDTH				: integer := 14;
		AMP_DATA_WIDTH 			: integer := 16
	port
		clk			: in std_logic;
		reset			: in std_logic;
		trunc_phase	: in std_logic_vector(TRUNC_PHASE_WIDTH-1 downto 0);
		amp_data		: out std_logic_vector(AMP_DATA_WIDTH-1 downto 0)
end amplitude_lookup;
architecture sine_lookup of amplitude_lookup is
	signal quadrant 	: std_logic_vector(QUADRANT_WIDTH-1 downto 0);
begin
	quadrant <= trunc_phase(TRUNC_PHASE_WIDTH-1 downto TRUNC_PHASE_WIDTH - QUADRANT_WIDTH);
	lookup :	process(reset, clk, addr, quadrant) is
	begin
		if(reset = '1') then
			amp_data <= (others => '0');
		elsif(rising_edge(clk)) then
			case quadrant is					--<<<< ERROR HERE <<<<
				when "00" =>
					amp_data <= ...
				when "01" =>
					amp_data <= ...
				when "10" =>
					amp_data <= ...
				when "11" =>
					amp_data <= ...
				when others =>
			end case;
		end if;
	end process;
end sine_lookup;
I've seen people having similar problems.
to:
signal quadrant 	: std_logic_vector(1 downto 0);
which is effectively the same thing, I don't get an error. I would have thought that since I've declared QUADRANT_WIDTH at compile time, the compiler would be able to handle it.
Is that not the case?
