[AVR] array intialize problem (avr-gcc)
firewhale
Junior Member level 1
i have a big problem when using array
the array works until my array is 4
but after i add 5th number, avr started joking....
the program very easy & problem seems very old
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#include <avr/io.h>
#include <avr/delay.h>
#include <avr/pgmspace.h>
int main(void)
    uint8_t i = 0;
    const uint8_t j[] =
    0x00,0x01,0x02,0x03,0x04,
    DDRB  = 0xff;
    PORTB = 0x00;
    for(i=0;i<4;i++)
    PORTB=j[i];
    _delay_ms(500);
& ex:when i remove 5th value, array restore correctly
with or without PROGMEM program not change
Try using a fixed size array, such as
const uint8_t j[5] =
not change with static or fix array...
joking like joke... i think it....
sorry for bad English
provide a minimum code that reproduces the error and what we should do to get the error you mention
this means you have no same problem...?
The provided code doesn't show any problem for me
when I run it in the debugger and vie the content of j I see all five values as expected.
Note that the condition in the "for" loop
for(i=0;i<4;i++)
Will only be executed four times (i=0,1,2,3) and not five, I wonder if this is the problem you refer to.
maybe makefile are diffrent...?
my problem is:
with 4 value{start show me correct value on led}
with 5or more{ from start show me evrything (65,84,0 0 0 ,....)& dont stop ,never(without loop).}
it seems my avr go crayzy with 5 value.....
can you attach your makefile.
I use AVR studio which generates the make file automatically.
I'm attaching the project which includes the make file (mcu is mega8)
  • conns.zip
no, no, no, no,
i can't use your make file
Code Bash - [expand]
make: *** No rule to make target '../conns.c', needed by 'conns.o'.  Stop.
when i use
Code C - [expand]
PORTD=j[4];
code work well,ofcurse output seems be convert to inline(becuse output hex are incrase)
your code work well ,you&me use avr-gcc but what does linker to me ,why?
I'm using AVR studio and winavr(installed separately), where does your avr-gcc installation come from?
Can you attach your make file?
You have Atmel studio installed? Which version?
You are using the integrated tool chain right? (no separate avrgcc installed)
So you have installed winavr?
Do you have the latest version?
only avr-gcc . no winavr no avr-studio
