[SOLVED] Are my solutions correct?
Ohman
Newbie level 3
Hello, im practicing on my exam to come, and im trying an old exam, i did answer two questions but im very unsure wether they are correct or not, since it was a long time since i wrote VHDL. I would appreciate if someone could check those answers and tell me if something is wrong :).
a) using VHDL, implement a component for a full adder, using A,B and Cin as inputs, R and Cout as outputs
solution:
entity FullAdder is
 Port(A,B,Cin: in std_logic;
        R,Cout: out std_logic);
end FullAdder;
architecture Behavorial of FullAdder is
begin
Cout <= (A and B) or (A and Cin) or (B and Cin);
R <= A xor B xor Cin;
end Behavorial;
b) using VHDL, implement a 4 bit adder using the full adder
solution:
entity FourBitAdder is
  Port(X,Y: in std_logic_vector(3 downto 0);
         [B]Ci: in std_logic;[/B]
         S: out std_logic_vector(3 downto 0);
         [B]Co: out std_logic);[/B]
end FourBitAdder;
architecture Behavorial of FourBitAdder is
  signal c : std_logic_vector (2 downto 0):="000";
  component FullAdder
    R, Cout: out std_logic);
  end component;
begin
bit1: FullAdder port map (A=>X(0), B=>Y(0), R=>S(0), [B]Cin=>Ci[/B], Cout=>c(0));
bit2: FullAdder port map (A=>X(1), B=>Y(1), R=>S(1), Cin=>c(0), Cout=>c(1));
bit3: FullAdder port map (A=>X(2), B=>Y(2), R=>S(2), Cin=>c(1), Cout=>c(2));
bit4: FullAdder port map (A=>X(3), B=>Y(3), R=>S(3), Cin=>c(2), [B]Cout=>Co)[/B];
end Behavorial;
//ohman
where is Carryin for first stage in entity declaration?
Reactions: Ohman
    Ohman
declare carryin and carryout in the four bit adder entity.
Reactions: Ohman
    Ohman
Thanks for the help!, i added carryin and carryout for the entity, but im not sure if i used them correctly in the behavorial. Changed code is in bold font!
Oh yes forgot to change that, does it look OK except for that?
thanks
yup rest look ok
just simulate it for sure
Reactions: Ohman
    Ohman
hello,
no need for specifying dat way, jst call it with dis command... this works fine
bit1: FullAdder port map (X(0), Y(0), S(0), Ci, c(0)); i mean no need for => signs and mentionin the var name of the component...
Reactions: Ohman
    Ohman
Ok but then i assume i would have to change the order, dependent on the order i wrote the ports, so this would be correct:
bit1: FullAdder port map(X(0),Y(0),Ci,S(0),c(0));
am i right?
