[SOLVED] Are Dual Contacts mandatory?
swordfish01
Junior Member level 3
[solved] Are Dual Contacts mandatory?
I'm doing the layout for some circuits for the H35B4 Technology from AMS. Normally I use multiple contacts when layout transistors (e.g. for drain, source etc.), but now I have an inverter that is pretty small (0.8 over 0.35 and 0.4 over 0.35). Should I layout the thing with also two contacts per terminal? Until now I never had the problem, since the transistors where not that small...
We learned to use multiple vias when switching metal layers, there it is not a problem, here it starts to look really awkward, since the contact have a minimum size of 0.4...
Regards,
Andreas
I would strongly recommend doing atleast 2 contacts.. I know its hard/a pain when your in min size transistors but its a good habit to always have atleast two!
Jgk
Thanks for your quick answer. I made most of those transistors with two contacts already, but I was wondering whether I could save the area/work to do it...
So be it, let there be contacts :) ...
Regards,
Andreas
I'm doing the layout for some circuits for the H35B4 Technology from AMS. Normally I use multiple contacts ...
... here it starts to look really awkward, since the contact have a minimum size of 0.4...
AFAIR double contacts are not enforced for 0.35µm processes (I think this changed at process sizes ≤ 0.18µm). However: would you risk a yield loss due to a loss of function of this transistor, for such a small win of area?
@erikl: No surely I would not want to have a malfunctioning transistor, but since there is no according design rule I wanted to ask.
This is purely a yield calculation. Personally I don't ever,
but I do double up vias as these are a much lower yielding
chain in my processes. Never seen a contact chain fail.
What is your (say) -3sigma contact yield, how many
single contact devices are in your circuit, and how much
yield does that say you'll eat? If it's sub-%, fuggedaboudit.
10%, start driving the single devices out of the design.
Designing analog - with usually enough space in our long transistors - we'd probably never see when one of the multiple contacts fail.
That's exactly what I wanted to tell! ;-)
