skatefast08
Full Member level 3
I am designing a 2.4 GHz pre-amp, is it required to have 50-ohm transmission lines (microstrip I'm guessing) at the nodes of the circuit? or will regular copper work? should I put components back to back with each other, or put 50-ohm transmission line in between? or could I just use a regular multipurpose pcb board and solder the components together?
