Arduino Mega 2560 with 2 x TLC5940
boylesg
Epping, Victoria, Australia
I have these connected up on my breadboard.
Connection of the two TLC5940s is pretty straight forward.
But connection of these to my arduino Mega is giving me problems.
I am using this library in the arduino development environment: https://code.google.com/p/tlc5940arduino/
I have connected up the TLC5940s according to this: https://code.google.com/p/tlc5940arduino/wiki/ArduinoMegaHardwareSetup
However my test LEDs are not lighting up at all.
In tlc_config.h there is this:
/** Determines how long each PWM period should be, in clocks.
    \f$\displaystyle f_{PWM} = \frac{f_{osc}}{2 * TLC\_PWM\_PERIOD} Hz \f$
    \f$\displaystyle TLC\_PWM\_PERIOD = \frac{f_{osc}}{2 * f_{PWM}} \f$
    This is related to TLC_GSCLK_PERIOD:
       \frac{(TLC\_GSCLK\_PERIOD + 1) * 4096}{2} \f$
    \note The default of 8192 means the PWM frequency is 976.5625Hz */
#define TLC_PWM_PERIOD    8192
So the pin 18 of the TLC5940 connected to digital pin 9 of my arduino mega should be oscillating at 0.9kHz.
However if I measure digital pin 9 of my arduino mega with my multimeter in frequency mode there is no oscillation.
If however I measure digital pin 12, which is connected to the BLANK pin of the TLC5940, then I find IT is oscillating at 0.9kHz.
So has anyone used this library previously and knows what the proper pin connections for an arduino mega should be.
Clearly the GSCLK pin of the TLC5940 should be connected to digital pin 12 and not digital pin 9 of the arduino.
But what about the other TLC5940 pins? Which are the correct pins on an arduino mega for these?
