silvio
Advanced Member level 3
download apbuilder
ApBUILDER is a software tool produced by Intel that can assist you to develop assembly-language code, such as peripheral initialisation sequences, for Intel microcontrollers
It allows you to have all information on the 8051 and its Intel derivatives on you desktop.
It links to the manual, allows you to configure registers, serial port, etc and will give you code for the hardware setup in both assembly and C
You can find original description here: http://www.intel.com/design/att/SIA78.PDF
You can downloaded (3.5 MB) alternatively, if one among links is not working, from here:
http://www.8051.co.kr/html/download/COMMON_PDS/data/apbld221.zip
http://www.acfr.usyd.edu.au/teaching/4th-year/mech4710-uP/material/ref/intel/apbuilder/apbld221.zip
http://www.jkmicro.com/newsite/downloads/zip/apbld221.zip
However, you must be aware, as mentioned here:
This tool is NOT a substitute for your knowledge of the functioning and correct use of on-chip resources. If you do not gain this knowledge through reading and experimentation with the microcontroller, ApBUILDER will just confuse you.
I apologize if has been posted before on elektroda.
Regards,
Silvio
Regards,
Silvio
