ehsanelahimirza
Full Member level 6
- Joined
- Feb 24, 2006
- Messages
- 334
- Helped
- 28
- Reputation
- 56
- Reaction score
- 7
- Trophy points
- 1,298
- Activity points
- 3,570
hi everyone
i have APC Back-UPS CS 650. it is giving low output voltage on battery mode if the load is reduced. nominal voltage is 220V AC, when i have load of one CPU and one Monitor then output voltage on battery mode is 204 VAC, but if i turn off the monitor to reduce load, the voltage drops to 170VAC and the CPU restarts. can anyone tell me what would be the problem with UPS.
plz note that battery voltage are 13 VDC and remain normal, and UPS output voltage when AC main is applied remains at 220 VAC regardless of any load changes.
Thanks in advance
Thanks in advance
