anybody knows such PA mmic?
dushan1
Member level 2
Member level 2
Is there anybody knows such PA mmic:
gain>14dB.
Pout_1>30dBm.
frequency range 5.85ghz-6.65ghz.
internally matched
The closest thing I found with a five minute search is the Fairchild RMPA61810
Typical 19dB gain at 6GHz
31dBm at 1dB compression.
From the S11 and S22 graph the matching looks ok to me.
It's specd for 6-18GHz so you would be running it very slightly outside it's spec.
https://www.fairchildsemi.com/pf/RM/RMPA61810.html
thank you,but i need a packaged.
you can try the FMM5056VF from Eudyna (ex-Fujitsu)
5.8-7.2Ghz
p1DB=34dBm
package in a VF package
hope this help
Sunny
thanks you,but i want a plastic packaged.it's cheap.
